Emerson 32 inch won't come out of standby mode
I just got this TV on black Friday and just hooked it up. It worked just fine. I had to leave for class so i pushed the power button on my remote and the TV went off. I came back from class and tried to turn the TV on. The light indicator flashed red a few times and then you hear a 1 second snippet of what was on the TV and then it shuts off. I tried different outlets, i tried different power sticks, i held the power button, and i disconnected everything and let it sit for a while hoping it would reset but nothing happened. What could possibly be the problem with it when i just took it out of the box? Why doesn't it come out of standby mode when i push the button?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It clearly has a problem not allowing it to come on---the set has a warranty---take it back and either get an exchange---Most major stores will exchange in first 30 days for any reason---if they give you the "it has to go for repair," demand a refund on the spot.
Frankly Emerson is not a very good quality brand and parts and support are nearly zero.
Posted on Dec 04, 2012
Testimonial: "Thank you so much. "
  • 7 Answers
SOURCE: tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Posted on Aug 31, 2009
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
dsacco86
  • 1077 Answers
SOURCE: My 32 inch emerson powers up and cuts off after a few seconds.
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again. d66cb18.jpg
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com:
http://www.tvtechcenter.com/xcart/search.php?mode=search&page=1 It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15.
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Posted on Sep 10, 2009
Raditronic
  • 196 Answers
SOURCE: AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
I got a Emerson 50" on Black Friday! Wii on component input has no red in the picture.
Try another component video cable. It sounds like the red signal isn't getting to the TV.
Nov 29, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
32'' emerson tv says digital telivision then nothing
press power screen reads digital television then the power light and stand by light turn on then screen goes black
Nov 26, 2012 | Emerson Lc320em1f TV
How do i hook my ps3 up to the tv?
See if the HDMI is plug in in the right plug in. If not then maybe you got to do something with the TV
Dec 22, 2011 | Emerson LC320EM8 32 in. LCD TV
How do I hook up my Wii to my 32" Emerson lcd hd tv? I have my dishnetwork satellite hooked into the dvd player and it's hooked up to the TV. On my remote I don't see a "game" button like my older Emerson...
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
May 04, 2010 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
