The factory setting for this apex tv is very loud. It's as low as it goes before zero and still too loud. Is it possible to adjust?
    President:
  • 1,082 Answers
Hi. I don't know your tv, but it maybe the type of sound setting is the issue. You should be able to find where you can choose the audio "Profile" like Mono, Stereo, external amp, etc.. Or you may options like Theater, Personal Music etc.. These settings can change how the volume reacts. I would suggest you try differnt settings to see how they affect it. Good luck.
Posted on Dec 05, 2012
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: recently bought a 32inch Dynex
Does the problem persist on all input sources(such as DVD)? Please provide this info so that I can point you to the source of the problem.
Sai.
Posted on Jan 18, 2011
Apex TV Service Mode
The service menu for this TV may be accessed by holding down the INPUT button on the TV and pressing 2580 on the remote. To navigate the service menu use the arrow keys on the remote. The center Enter button is used to go down into a submenu. The Menu button returns from a submenu. The exit key exits the menu.
There is an option to adjust Over Scan in the Picture settings menu. Set the positions to zero and the size to +100 for both horizontal and vertical. Then set the Sharpness to zero in the Picture Mode menu for each picture mode (optional, but sharpness makes text and sharp lines really ugly if you're using a PC).
I've owned this TV since Feb. 2013 and I've been disgusted with its lack of disable-able overscan and forced to use VGA to get a usable picture. The VGA port finally started going out (flickering colors) and rather than tearing it apart to resolder the VGA connector I tried to find a service manual again. Found one for a different Apex LCD TV but the service code was the same. It's like having a brand new, much better TV now! Overscan is the worst thing the TV industry ever did, it's totally and completely unnecessary on digital, pixel-perfect signals.
Aug 06, 2014 | Apex'i LE4643T 46 inch Glossy Black 1080P...
Sound is not loud enough 22 inch flat screen sound isnt loud enough
you need to compare it with another set of the same make, if it's still not loud enough, it could be an ill adjusted factory setting, a mouse has invaded the TV and is living in the speaker, or you may be going deaf.
Oct 02, 2009 | Sansui DTV2760 27" TV
Apex 19" #LD1919
1. UNPLUG the TV from the wall or power strip.
2. Turn ON the TV (w/o the power plugged in).
3. Plug the power cable back in.
4. Turn ON TV ... it should work...
5. Also... adjust antenna if you are on "broadcast" mode.
Sep 03, 2009 | Apex Digital LD1919 19 in. LCD TV
Volume too loud
Very likely the volume setting on your cable is set too high. The cable volume is separate from the TV volume. Once you lower the cable volume, then you can adjust your TV volume to find a happy medium that gives you more range between numbers. Have you already tried this?
Apr 18, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
Need to cancel weekly record on my Apex VCR-DVD
HAVE YOU TRIED SETTING ALL YOUR TIMERS TO ZERO, ROB
Feb 20, 2009 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Apex pf3225 picture is to wide for the screen
I was able to get a good picture by doing the following. Using your PF 2025-3225 remote:
Press the volume to zero
Pressmute on the remote and hold (tv should say mute)
hold the menu buttuon on the tv
There are 10 menus as you press the arrow buttons, go to the first with anything "H". you will use the "e/wide" and "H" item also Trapzium and the parabolic setting and slowly use these until you get the desired quality.
The go to the "V" menu and adjust carefully until you get the desired quality. Do not adjust anything that is already set to 1 or 0, If you do and you get a blank or lined acreen just press the opposite arrow and it should go back to your picture.
Power off and on after you see a good picture.
You could use your cable guide or DTV Playlist as your picture as they have alot of items in the corners. that is how I did it, it worked for now.
Dec 09, 2008 | Apex Digital PF3225 32" TV
APEX Television
1234, if the factory setting...accordianman
Jan 08, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Hello
You can try to use the "common code" - 0- all zero's. Unless you have an actual code that you have set up in the TV. Another way would be to unplug the TV for a day, or try to remove the fuse in the back.
Dec 29, 2007 | Apex Digital AT2702 27" TV
Car stereo receiver
Maybe the owners manual would help. It says you can adjust the sensitivity of the AUX input through a menu. It sounds like the AUX sensitivity is just set to max. Look for the 'to change other settings' chapter, instructions are in there.
If you don't have the manual, find it on the official website.
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
The link to download it is on the upper right.
Apr 23, 2007 | Clarion DXZ555MP CD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
