Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
Report abuse posted by OG on Jan 12, 2009 My Whirlpool Conquest 25.55 cu. ft. Model # GS6SHAXLQ01 is about 7 years old. I left it on when I was out for 4 weeks. In my absence there was a 15 hour power failure. On return I found that although the lights and the sound of the motor running are OK, but it is NOT cooling and also NOT making ice. I emptied and cleaned it throroughly. I also vaccumed the condensor coils behind the front grill at the bottom. It was very dirty. Then I started the refrigerator again but it is still NOT cooling even after 6 hours of running even though the lights are ON and the sound of the refrigerator running seems normal. Ice is NOT forming but water does flow out of the dispenser. CAN SOMEONE PLEASE HELP.
  • 4 more comments
  • OG Jan 12, 2009
    Thanks for your quick response. As far as I can make out the fan inside the freezer compartment is working. The fan at the rear bootom was relaced 5 -6 months back and I think that also is working. The water is flowing out from the dispenser. BUT THERE IS NO COOLING.
  • OG Jan 12, 2009
    Thanks again. I removed the hard board cover. The compressor is slightly warm but there is NO sound coming from it. Seems it is NOT running. The fan on its right rear at the bottom is however running. The copper pipes from the compressor are neither hot nor cold.
  • OG Jan 12, 2009
    Thanks a lot Ken. I am NOT sure if I can locate the relay. There is WHITE 3 inch x 2 inch ceramic or plastic part attached to the LEFT side of the compressor. It has TWO wires coming to it - one is a BLUE wire with a copper color ending. The other is a WHITE wire with a BLACK colored ending. I have unhinged the copper colored ending. Before I unhinge the BLACK colored ending I just wanted to make sure that I am not making a mistake. THANKS A LOT for your Help and guidance.
  • OG Jan 12, 2009
    Hello Ken Thanks a Ton. I have pried out the 3 inchx 3inch x 2inch part which was attached to the LEFT side of the compressor - BUT IT IS CREAMISH YELLOW in color. Is this the RELAY? There is another BLACK component aboUt 3 inch x 4 inch towards thE back side of the compressor which is bolted to the floor of the refrigerator. The BLUE and WHITE wires were attached to its top. My doubt is whether that BLACK component is the relay since you had earlier mentioned that the relay is BLACK or is it the WHITE one.. However the WHITE component which I have pried out had FOUR wires going into it and had has three sockets into which the three pins on the compressor wall go in. It has the words "4SP" embossed on it and below it smaller numbers "4SP1001" and "2212194" and below it "14 F02R". If this is the relay then I will take it along to get its replacement. SORRY FOR SO MANY QUESTIONS - BUT I HAVE LITTLE KNOWLEDGE ABOUT THESE THINGS AND I DO WANT TO SAVE SOME MONEY IN GETTING THE REPAIRS DONE.
  • Ken Bledsoe May 11, 2010
    Can you tell if the compressor is on might have to remove the back cover on the back side of the frig. It is a card board cover.
    Are both fans running the one inside the freezer compartment and the one down by the compressor?
  • 306 Answers
You have a relay on the compressor called a PTC relay. That little guy is bad. Make note of the wires and where they go. Take the relay and make and model number to a appliance repair house and get a new one. To remove the relay you have to remove the wire retainer clip and take off black cover then pry off the little relay they are on snuggly just pull straight off. let me know if I can help any more. ken
Posted on Jan 12, 2009
  • Ken Bledsoe Jan 12, 2009
    Yeah your on the right track. When you pull the PTC relay off flip it over and look inside you will see that it got over heated. Should be able to see it very easy. ken here in Kansas
    Yes that is the relay the other device is a capacitor. But the three prongs you described tells me that you got the right part. Make sure the wires are put in the right place when you get the new relay. And just in case they don't have the relay you can get a 3 in 1 relay. Also for info need make and model number when you go and get one. Some relay's are black some are white so color is one thing I should have left off. So not to confuse anyone. Talk to you some other time. And thanks for the rating as helpful. ken
We bought this whirlpool conquest off someone and was wondering how long it takes for it to start cooling?
Hi!!
A refrigerator unit can take up to 24 hrs. to reach desired temperature when first connected or when moved or disconnected for more than one day.
Don't forget to rate this post!!
Sep 30, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
WHIRLPOOL Relay melted! PLEASE HELP! 1 of 3 Compressor Pins melted! HELP!
Hi, If the pin on the compressor is melted/broke off, the compressor is bad. If the unit is under five years old, check with whilpool and see if it still has a warrenty.
I hope this helps.
Please let me knwo if I can assist you further.
Vic
Jun 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not cooling or making ice - fan and lights OK
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
iufgh
Jan 12, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Refrigerator not cooling although lights and sound are OK
heatman101
\ fbvb
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
473 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
