Question about Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489
Water in the oil - Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489
  • javier flores Dec 04, 2012
    every thing is working but right above where the hose go connected water is coming out and oil and when i check there was water in the oil
    New Friend:
    Problem Solver:
  • 13 Answers
Sounds to me lyk it needs a new gasket
Posted on Dec 05, 2012
How do I fix oil being in my radiator but no water in the oil? Oil is not milky or anything on the stick just looks like oil in radiator.
Replace the thermostat. Empty all of the water out, flush with water and a good squirt of dish liquid and run until hot. Drain again and refill with plain water. Empty that and fill with water and anti-freeze.
The air conditioning is completely separate, a standalone system run from a belt on the crankshaft pulley.
Sounds to me that someone has put oil into your water instead of the engine.
Aug 16, 2015 | Jeep Cars & Trucks
My problem is toyota 2lt engine oil in water the oil is clean
Check the engine's oil dipstick. Brown, bubbly oil or any inconsistencies or traces of water on the dipstick can be symptoms of a severe head gasket failure. Have the car's engine checked right away. god bless!
Apr 03, 2014 | Cars & Trucks
Water get into oil
Water in oil makes the oil go grey / milky or white . Check the cooling system by a pressure test and if it is holding then it will not be water in the oil.. If you are referring to transmission oil then the tan colour indicates burnt oil, and must be replaced. Water in that oil will also be a white cherry/ milky colour.
Mar 18, 2014 | 1993 Buick LeSabre
Refrase 1996 hyundai excel ,oil in water no water in sump oil.
Oil in the water is usually a sign of a head gasket leak, because the high pressure oil passes through to the head in order to lubricate the camshaft.
The oil return passages also go through the head gasket, but are too low pressure to usually cause any problem.
As long as there is no water in the oil or loss of water, I would keep driving it.
The oil in the water will not hurt anything. If it eventually gets worse and leaks water, then you will have to do the head gasket. Costs about $500.
Of you can do it yourself for about $75 if you know how to use a torque wrench.
Jul 03, 2012 | Cars & Trucks
I have oil in my water resivior and its overflowing with oil.
Sounds like you have a leak that may be due to a bad seal,a bad gasket or a cracked head. When the engine is running. Oil pressure is higher than water pressure. But when the engine is shut off oil pressure goes to zero but water pressure is still at 15 psi. untill the engine cools off. that's when you get water and oil to mix. If you do an oil change you could find water in the oil pan. Doing a water pressure test will verify a leak but won't tell you where.
Nov 23, 2010 | 1999 Cadillac Catera
1993 camaro V6 3.4 lt water and oil mixing could it be water pump
Yes there is another way, someone can be messing with your head and pouring water in your oil cap. Do have water in your oil or oil in your water or both? A product called sea foam does a miraculous job at getting water out of oil. As far as keeping it from happening further, the cheap way of course is "bar's stop leak" but man can this stuff do a number on clogging your heater core, even if they say it doesn't, it can happen.
Jun 07, 2010 | 1993 Chevrolet Camaro
Perkins 7.5 gen. I am getting oil in the water ,
your water jacket in the block has a pin hole in the block and the pressure of the oil versus the water is higher and forcing oil into the water you need to put dye into the oil and water and trace the leak,then "magnaflux" the block and repair it
Nov 14, 2009 | Electrical Supplies
Nissan Sentra GA14 engine - Water in Engine Oil
If the engine has been flushed well including the radiator and you are still getting water in the oil. The culprit is the cylinder head or the block has a crack internally allowing water into the oil.
Oct 10, 2009 | 1997 Chevrolet Monte Carlo
Had water pump changed on 2003 Highline Jetta 1 month ago. Oil cooler had to be replaced 1 month later. Oil landed up in water - oil totally empty. Temperature gauze said "Check coolant". Muddy consistency...
sorry to be the messenger of bad news but from the symptoms described it sounds like the head gasket ,the oil feed to the camshaft to be more precise ,its forcing oil into the water circuit but the water is not getting into the oil because its at a lower pressure .
Jun 20, 2009 | 1997 Volkswagen Jetta
Leaking both oil and a mixture of oil and water
well when you have water and oil both leaking it most of the time means a head gasket or in your case a jug gasket
May 25, 2009 | 2004 Yamaha YZ 250
Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489 Logo
56 people viewed this question
Top Troy-Bilt XP Garden Experts
CrisO
Ron Durham
Bill Boyd
Are you a Troy-Bilt XP Garden Expert? Answer questions, earn points and help others
