Question about Food Mixers
I can't open my kmix stand mixer
I can't get my kmix stand mixer to open. The release lever at the side does not seem to depress properly, and I just can't get the top of the machine to move at all. No idea what has happened, as it was fine last time I used it (only a couple of weeks ago). I'd appreciate any ideas as to what has gone wrong, and how I can put it right. Coming up to Christmas I really need to use the machine!
How do I take the gearbox out of my kmix stand mixer
Hi Carol!
Here is a link to your mixer Manual.
Hope it is helpful to you,
JP
Kenwood KMX50 series Instructions Manual
Jul 16, 2015 | Kenwood Kmix Kmx51 Stand Mixer
How do I take the gearbox out of my krnwood kmix
Hello Carol Wink,
Here is a link to your Kenwood Mixer operating Manual.
Everything is in there. You can View it, Download it or Save it to your PC.
Good Luck!
JP
Jul 16, 2015 | Kenwood Kmix Kmx50 Stand Mixer, White
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
Apr 29, 2017 | Kenwood Kmix Kmx50 Stand Mixer, White
Kmix mincer not rotating
Hi, it sounds like a broken gear.
Send me your email
Aug 12, 2013 | Kenwood Ax950 Attachment For Kmix Stand...
Model K5SS -- The speed control lever will not stay in the slowest position - STIR - but will pop over to the next position - 2. Can I adjust anything to fix this problem?
Open up the Motor Housing and inspect the Switch Lever with Stud.
The Lower Gearcase has many depressions which allow the stud to
snap into it when the Speed Selection lever is moved. If the Stud
is worn out then there isn't much you can do but replacing it.
3184193 is the Switch Lever And Stud part number for your model.
Jul 03, 2011 | KitchenAid K5SS Heavy Duty Commercial...
What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Jul 19, 2009 | Kenwood KM800 Major Classic Stand Mixer
Can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements each have adjustable heights. to adjust the height you need to loosen the bolt at the top with a 14mm spanner. If the bolt was loose when it was being used then it can get too short and not leave enough clearance between the bolt and the machine in order to push up and turn to release the implement. If this happens take the open ended spanner, grasp the implement and rotate the spanner clockwise (when looking up at the machine from below. Once the nut is loose rotate the implement until there is enough clearance to remove it normally.
Jun 05, 2009 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
643 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
