Question about Daewoo DTQ-26S1FC 25" TV
NO PICTURE I HAVE A DAEWOO DTQ26S1FC MODEL FROM 1999. IT HAS ALWAYS WORKED GREAT. I RECIENTLY TURNED ON THE TV AND HAD NO PICTURE. I TURNED IT OFF AND ON AGAIN AND GOT THE SOUND AND NO PICTURE. THEN I UNPLUGGED IT AND GOT A BLACK SCREEN WITH A VERTICAL STRIPE OF COLOR DOWN THE MIDDLE ( i could see that it was the picture but I could only see a sliver of it.)i TURNED THE TV AROUND AND CHECKED ALL OF THE CONNECTIONS AND FOUND EVERYTHING TO BE WHERE IT BELONGED. i JIGGLED THE POWER CORD AND THE PICTURE CAME BACK ON.I HAD THE PICTURE BACK FOR ATLEAST 2 WEEKS.THE OTHER NIGHT I TURNED IT ON AGAIN AND IT WAS DOING THE SAME THING AGAIN WITH SOUND AND A STRIPE OF VERTICAL COLOR AND I CANT GET IT TO GO BACK. IS IT JUNK OR IS IT FIXIBLE???? TERRI
  • Anonymous Aug 19, 2008
    no picture no sound
  • 883 Answers
There is a broken conductor strip or broken solder joint on the circuit board near the power input jack. do this: 1.) disconnect tv and open panel to expose circuit board. 2.) using a flashlight and magnifying glass, look carefully for this broken solder strip or solder joint. Flex board slightly if necessary to aid in finding the break. 3.) repair it using solder iron and flux solder and scratch copper conductor slightly to aid in "wetting" the solder fix.
Posted on Jun 09, 2007
SOURCE:
Please show me a picture that shows the position of oxygen sensor on a daewoo lanos 1999 model 1.6 litre
Oxygen Sensor
1999 Daewoo Lanos 1.6L MFI DOHC 4cyl
The Oxygen Sensor is located: Under hood, driver side, lower engine area, above exhaust pipe flange, mounted in exhaust manifold,don't have a picture.Here's a link to what it look's like just remove the electrical connector,get a open end wrench and remove.. http://www.autozone.com/engine-management/oxygen-sensor/bosch-oxygen-sensor/daewoo/lanos/1999/4-cylinders-6-1-6l-mfi-dohc/4971_102074_1784_97999
May 25, 2015 | 1999 Daewoo Lanos
No power
unplug the unit for 24 hours and try it again. if the unit doesnt come on at all, even after that, then the internal fuse is blown, or a power spike / surge has friend part of the internal power supply. you'll have the go through the warranty process of the manufacturer, or find a local tv repair shop.
Sep 24, 2009 | Daewoo DTQ-27S5FC 27" TV
Daewoo lcd dlt 20w2
Hi this is warjis ahmed,
I can solve your problem of DLT-20W2
My email> warjisahmed@hotmail.com
Oct 29, 2008 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
Timing,Daewoo 2000,Nubira
timing belt off by a tooth or two........ recheck the timing.........rate as fixya justuscc also make sure you didnt bend a valve or two
Oct 28, 2008 | 1999 Daewoo Lanos
Daewoo Universal Codes for Comcast Remote
For Daewoo TV Model DTQ-27U4SC, try this for Comcast Universal Remote (one with the red select button):
1. Press TV button
2. Press Setup button until TV button blinks twice
3. Enter 10451
4. Press Power button (TV should turn off and is set)
Mar 01, 2008 | Daewoo DTQ-1440FC 13" TV
Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Feb 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Pd46c10 daewoo plasma
I have a DAEWOO PD46C10 recently it would come on display a beautiful picture play for 10 minutes and the screen would go black.After several minutes reset turn it on and the process starts again.Whats the problem and where can I get it repaired???????????
Nov 25, 2007 | Televison & Video
Problem with picture
Go into your menu system and turn off the closed caption.
Bill
Nov 20, 2007 | Televison & Video
No picture at all on daewoo lcd tv
I have a problem that looks similar. After some research and troubleshooting, I believe that the problem with my TV is the A/D decoding chip that takes care of the component video inputs. These chips are not simple analog to digital converters. They understand the component video (YPbPr) signals and need to sync to them at the various transmission frequencies and convert them to 3 digital YUV data streams with the correct number of pixels and dimension. I am only a computer engineer, but I guess these chips probably aren't very reliable or last very long... Try to use your TV with different input connectors and resolutions. If some of them work correctly, it is likely the A/D thing.
Aug 03, 2007 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
Daewoo DTQ-26S1FC 25" TV Logo
171 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
