Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Fridge section runs warm. Freezer ok it seems.
Recently had fridge and freezer running warm. I repaired broken fan wire in freezer. But fridge section still warm. Fridge fan runs fast for a short period of time before slowing down. (after door shut)
  • Anonymous Mar 13, 2014
    fridge and freezer warm
  • 306 Answers
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Posted on Jan 12, 2009
Fridge warm and freeze cold
Rachael, I recently had a similar issue. Unfortunately, the problem you describe could be related to several components & sensors that could have failed which cause similar symptoms. There are a few things that you will need to start with in order to best lead you in the best direction for repair. First, ice building up says that there may be a problem with the auto defrost cycle. Usually a sensor that sits on the evaporator in the freezer side. You want to start with actually measuring the temp in the freezer and the fridge. If you can, remove items, turn fridge off & then unplug fridge from outlet. Let sit overnight with doors open. Two goals, here. One, ensuring that any ice that has formed in the air passages has a chance to melt completely. Second, unplugging the fridge helps "reset" the control module. You stated "hearing the motor" working. Do you mean the compressor or the fan in the fridge. IMPORTANT, you need to make sure that when the fridge is "running" that you can feel air blowing in the freezer & fridge section. Do this before turning off & unplugging. Lastly for now, did anything out of the ordinary happen before you noticed improper operation?
Jan 15, 2014 | Frigidaire Refrigerators
Freezer works, fridge does not. Also the sides of the fridge are really hot but not up the top near freezer section. Fridge has recently been moved. Thanks
Warm sides are usually caused by the condenser fan which is underneath around back not running. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
When it was moved, was it laid down? If it was it should be stood upright for 24 hours before being plugged back in.
Feb 13, 2010 | Refrigerators
The fridge section is warm, the freezer is OK
sounds like the circulating fan is wearing out. This fan supplies circulation for the freezer as well as the refrigerator when the motor for this fan starts to wear out the circulation supplied is reduced to a point that the freezer will work but not the refrigerator because the fan does nnot run fast enough to circulate the air thru the refrigerator. The minimum cost to repair/replace this fan assemble is around $300.00
Jul 11, 2009 | Refrigerators
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
Freezer working, fridge not
Possibilities include inside fan unit not running for some reason, thermostat cycling the unit off before its cold, compartment light staying on, damper adjustment set too warm or broken or blocked. There are others but less likely.
Jun 04, 2009 | Magic Chef CTB1922 Top Freezer...
Freezer freezing great, Fridge running warm
Hello Murr9,
The number 1 reason a freezer "SEEMS" to be working... but the refrigerator isn't cutting it... is PROPER AIR FLOW...
look through the vents in the back of the freezer section...
If you see thick frost or ice... you have found your trouble
If the evaporator fan (behind the freezer wall is operating at ANY speed your REFRIGERATOR section would be adequate...
You had a repair person out... but
while that ought to mean something to me... I would rather
you do some simple checks...
- Look through those vents
- You need to check the defrost pan... DRY means you have
troubles... put a piece of fresh typing paper inside the pan...
fold it over the edge... if it is still dry the next day...
Your defrost circuit is broken...
It only has three components:
- heater element
- defrost thermostat (opens at room temperature)
- Printed Circuit Board
Your refrigerator DOES NOT have a defrost timer... but rather a PC Board...
($152, see below... plus how to video)...
Most expensive part but easiest to replace...
Important - Important - Important
TAKE PICTRES OF ALL THE WIRE
connections BEFORE you start.
http://www.appliancepartspros.com/whirlpool-timer-defrost-4388932-ap3109394.html
Get on AMAZON and buy yourself a couple of the TAYLOR REFRIGERATOR thermometers...
zero Fahrenheit is fine for the FREEZER...
REFRIG should be just above 32 degrees
Fahrenheit...
Amazon com Taylor Freezr Refrig Thermometer 1 pack of 3 items Home Kitchen
partsselect
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Mar 04, 2017 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Oct 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
THE MAIN FRIDGE IS NOT WORKING, THE TEMPERATURE SEEMS TO BE VERY WARM. THE LIGHT INSIDE THE FRIDGE IS WORKING OK AND SO IS THE SOUNDER WHEN THE DOOR IS LEFT OPEN.
Listen for the fan that is in the freezer section. The fridge part relies on the freezer fan to get it's cold air. Only the freezer section gets cold...the fan in the freezer blows cold air through ducting to the fridge to get it cool. Either the fan is bad or the air ducting to the fridge is restricted by ice. If the airway is restricted by ice then your defrost timer is bad. Good luck.
barneyluc
Oct 10, 2008 | Refrigerators
Cold freezer warm fridge.
That sound was the evaporator fan motor in the freezer. This circulates the cold air from the freezer into the fresh food section. If this is not running you need to check for power to it. If the fan has power to it but not running, replace it. It should be located behind freezers back wall inside of freezer near top.
Oct 09, 2007 | Refrigerators
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
651 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
