Question about Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05
Jacuzzi 52222-03 Balboa WH-R576-DCAH 240 v into board plugged in new display with nothing showing up?
2 Suggested Answers
SOURCE: I have a Balboa WH-R576-DCAH.
If the pressure switch is jumped properly and you still are not getting a call for heat, then you are having a problem with the circuit board and it most likely is going to need to be replaced.
If the heat light is coming on but no voltage is going to the heater, this would also indicate a bad board.
You can find the 52213 circuit board online at: http://balboadirect.com/52213.aspx.
Hope that helps.
Posted on Sep 21, 2011
I have a Jacuzzi spa with a Balboa R576 (522205) control box. The control panel constantly shows "OH" (overheating) even when the water temp is 50-100 degrees F. When I reset the system by flipping the...
There are some things to check.
Make sure the vents on your cabinet are not obstructed.
Make sure your filter cycle is not too long
Make sure you are not running high speed for more then 30 mins.
Have you looked through the Balboa error message site. I have attached a link follow your error through and you may find your answer. Diagnostic Messages
Mar 02, 2015 | Balboa BB58048 Jacuzzi R574 R576, 4.0KW,...
Do I have the correct controller for my Hot Tub? I have a Jacuzzi Lexus L.C. with a Balboa F1089R1A processor. I ordered a topside control panel online and received a Balboa VL701S but nothing is working...
Curios, why did you order another control panel? I need some history, when it worked, how it failed, any other information like if it was moved or rewired for power...etc.
Nov 13, 2013 | Jacuzzi Home
No temperature display cant set temperature
Located behind the access panel there is a grey box that is the spa pack. Open that up with the 2 screws on the top of the pack. There is a small glass fuse on the circuit board. One of those fuses is most likely blown. If that is not the culprit you need a new topside control. More than likely it's the fuse.
Mar 04, 2013 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have a Balboa WH-R576-DCAH. All controls seem to operate ok but no heat. Both motors seem ok, pulling about 5amps each. Not an expert but was able to manualy close the relay and cause the heater to...
Hope that helps.
Aug 02, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
We bought this house 4 years ago and have never used our Balboa jacuzzi ubnit in our master bedroom. we need someone to come to our home to check out the unit- (hopefully at not an exhorbitant cost) maling...
I will advice you get a technician to come to your house and take a look at it, since you are sure of the position or status of the Balboa jacuzzi, it will be better you get someone, a professional to help take a look at it, this is not (DIY) do it yourself as you can see.
Jun 13, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have a Jacuzzi circa 1998 model Z140 spa. The 50 amp gfi breaker is continually trippinhg. The electronic control box is a Balboa instruments MODEL, DU-H276-DCAH. A relay on the circuit board chatters...
Hello - sounds like you will need to replace the relay itself if possible, if not you most likely need to replace the circuit board considering its age.You can check by diconnecting the power to the board.
If you are not an electrition and you dont work with electrical STOP NOW!! and call electrition.
Following steps would be 1. Turn off breaker. 2.Disconnect wiring to the board. 3.Wire nutt off electrical to the board.
4. Turn breaker back on. If breaker does not trip , board will need repaired or replaced.
May 18, 2011 | Home
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
No power to the display panel
Watch the panel as somone turns the power off and on and see if anything shows up like dashes. The only way to check a panel/ keypad is with a good one
Oct 19, 2008 | Balboa Instruments Duplex Digital Panel 2...
Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05 Logo
344 people viewed this question
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
