Question about Hardware & Accessories
How do I connect my Jandy AE-TI heat pump to my intermatic T104P3
My Jandy Manual shows two closed loop connections to the pump time clock from the maintain temp relay. I need more specific wiring diagrams or specifications.
  • 13 more comments
  • Joseph Zebrook Dec 05, 2012
    Thank you Gene. I also assumed the load would be connected to the pump, but the diagram as you noted (6) the load is shown going to the "pump time clock". Closed loop is not only confusing but I think incorrect. In your diagram form (1), I assume that the Auto-Heat Contactor is what Jandy identifies as the Main Temp Relay. This explains Jandy's Auto-Heat mode (LED display). But how does the Jandy Pool mode (LED display) restrict the AE-TI heat pump to heating when only the filtration system is running?
  • Gene Haynes Dec 05, 2012
    I am timer expert, and very familar with voltages and contactors. The AE-TI is a new item for me today, and not my expertise. (1) Looking at Jandy wiring diagram ... I focused on words "Line' and 'Load' since these are universal notation in timer manuals. (2) Is the link to product manual identical to your manual? (3) How does Jandy know that heat pump should only turn ON when pump is ON? I don't know how it interfaces with the timer schedule? That seems confusing to me why you would need a T104 timer supplying power to that contactor, since the timer could be OFF all day, but heat pump turns ON the contactor.
    Let me think about this for a few minutes....
    Gene, I continue to think about this problem. Initially the Jandy wiring diagram in the Jandy Heat Pumps, Model AE-TI, Installation and Operations Manual seemingly had a confusing closed loop, but wouldn't Jandy have corrected that in one of their addendums? Assuming they would have done so leands to the inference that the Jandy wiring diagram is correct. Let's assume that it is. Then the following is a possibility. The T104 Clock Motor has two white leads connected to T104 Timer Terminals 1 & 3. These could be disconnected and lead as L1 & L2 to the Jandy Auto Heat Contactor diagram you supplied in your solution, step one. The outputs from the Auto-Heat Contactor labeled Load 1 & 2 to the Pump then could lead back to T104 Timer Terminals 1 & 3.
    Review timer functions: The clock motor must receive power at all times, or the timer is non-functioning because the dial does not rotate, and trippers do not move on-off lever back and forth. And then there is no time schedule.
    Read above, and then new comment here: What is purpose of T104 timer? Isn't the Jandy digital controller a full-functioning scheduler? The controller appears to be complex version of ordinary Deihl timer adapted to many different applications in pool/spa industry. If the Jandy controls the contactor to pump, why is the T104 timer needed? Maybe the T104 is a back-up. I'm still thinking.
    3rd comment. Wait a moment. The jandy digital controller is NOT a timer. It is a thermostat. Page 18 manual, #3 says; the heat pump will overrid the timer. Let me figure out the wiring for that.
    Disregard all above: Here is correct wiring diagram for thermostat override on timer:http://waterheatertimer.org/images/T104-... Wire it as shown is identical to how other thermostats by-pass T100 series timers and turn on heater when temperature drops below set point.
    * identical to how they turn on pump (not turn on heater)
    Gene, I really appreciate your help. I initially had an electrician come out and set up the wiring from the main breaker panel to my pool subpanel. On the main panel he added a 100A breaker to feed the pool subpanel. The existing pool subpanel has a 15A breaker for the pool light and a 20A breaker for the pool pump/timer. His plan was to add an additiona 50A breaker to for the Jandy Heat Pump. On Jandy AE-TI Installation and Operation Manual, Page 14, Figure 8, there is shown a Main Contactor with inputs L1 & L2 (see attached figure). I assume his plan was to power the Main Contactor, L1 & L2 with the 50A breaker. Again I really appreciate your help, especially since the electrician I hired hasn't come back to finish the job; though I've called him several times. I don'tplan to do the wiring myself, but I want to be sure that these so called certified electricians know what they are doing. I want to be smart enough to ask questions and understand the answers.
    Gene, I'm having trouble posting the figure.
  • Gene Haynes Dec 06, 2012
    Trouble loading the wiring image? Open link, and press Crtl+F5 to refesh page:http://waterheatertimer.org/images/T104-... I am formulating response to question about circuit breakers. If you have internatic control panel, then maximum circuit breaker size is 15 amp. You would use 14 gauge wire with 15 amp breaker. So the new 50 amp breaker for Jand will have to come from main panel of subpanel:http://waterheatertimer.org/How-to-insta... Let me know if you can load image. If I post image on fixya, then they own it, and the resolution is very low. Let me know.
    Would you tell me the model number of Intermatic panel that you have so I can look up specs on that breaker panel. My understanding is that these panels have maximum 15 amp breaker. I need to check that. For some reason my information does not sound correct. However if it is correct, then adding 50 amp breaker into Intermatic panel is not right. Let me check this information through Intermatic.
    Electrician added 100 amp breaker to feed pool panel. Did he install size 1/0 wire?http://waterheatertimer.org/images/Max-w...
  • Joseph Zebrook Dec 06, 2012
    Yes, he installed the correct size wire. Thanks for all your help. The problem is solved.
  • 5,245 Answers
1) Copy following link for wiring illustration ... assuming timer is supposed to control pool pump:
http://waterheatertimer.org/images/T104-to-contactor.jpg
2) T104P is 240Volt (208-277V) SPDT timer in P plastic outdoor enclosure.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Jandy AE-TI is 208/230V pool heater.
http://www.bestbuypoolsupply.com/media/aemanual.pdf
4) Page 13 of Jandy manual shows single-phase residential wiring diagram.
5) First of all, power to main contactor is not interruped by timer, since this powers 24Volt transformer that controls the chip board and general operation.
6) The timer is connected to 'Auto-heat contactor.'
The confusion is what Load connects to this contactor? The water pump? Load is shown on diagram as 'pump time clock.'
I assume the load is the PUMP??
Posted on Dec 05, 2012
MOTORWIZJ
  • 1363 Answers
SOURCE: clock for pool pump intermatic timer Model T104P3 stopped ticking
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY ..LOOK EBAY FOR .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX
Posted on Jun 02, 2010
MOTORWIZJ
  • 1363 Answers
LOOK HERE ON EBAY .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIXTO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY
  • 760 Answers
SOURCE: Wiring of Intermatic T8845pv
I believe the number you gave is fir the 14 day timer. Here is a link to the manual for it. Notice the not to use only one silver pin.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashx
Posted on Aug 10, 2010
SOURCE: I need contact points for Intermatic #ML300RTW or
ML300 is a Power Pack for outdoor lighting
A search of Intermatic site shows they no longer sell the product
Malibulights.com does not have any parts either
I have searched the web for parts in order to help fixya visitors, and I can't find any trippers or clock repair parts at all.
I bought a new Malibu 330Watt at Home Depot thinking the manual or box would show information>> but the new Power Packs have a digital clock, not the old dial clock with trippers.
Look like you have to buy a new Power Pack to fix the old one.
Posted on Oct 26, 2010
SOURCE: Intermatic t104p3 pool timer will
Thank you for including model number so answer can be accurate as possible.
T104P3 timer works with manual override so timer is basically sound.
Clock dial rotates and keeps good time, so WG1573 240Volt clock motor is good.
Trippers do not click on-off lever, so trippers are suspect.
Trippers are made to wear down so that timer mechanism lasts years longer.
Order extra clock motor and trippers at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See wiring diagram:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 18, 2011
Jandy ae heat pump
make sure wiring is correct for 220 volt or 115 volt and check fuses
Mar 20, 2013 | Jandy AE3000T AE-Ti Heat Pump 137K BTU
Where is the pressure switch on jandy pool water heater AE-TI
open front panel look for a white and copper triangular object with 2 wires connected and a copper tube
Dec 28, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
How do i fix H20 sensor on a jandy pool water heater AE-TI
remove the two black wires from the PCB board and remove the other part from the copper line going to the header where the pipes connect
Intermatic t104p3 pool timer will turn pump ""ON" with Manual Switch but will not shut "OFF" using Manual Toggle. Pool store showed me how to remove and look at the contacts on...
See wiring diagram:
Feb 18, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Jandy AE-TI H20 error message - pool not heating
just looked at the manual for this unit. It does not list an H20 code. Is this all it says on the screen?
Nov 13, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy AE.TI AE3000T .263 BOARD SHOW FAULT SHORTED H20 SENSOR
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Jan 08, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Hardware & Accessories Logo
279 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
