Question about Lexmark X215 MFP All-In-One Laser Printer
Error LSU I cant make a copy from my flatbed. A LSU error pops up
  • Official Brand Answer
  • 3,344 Answers
A problem in the LSU (laser scanning unit). Make sure all cables are properly connected to the printhead. If all cables are correctly connected, replace the printhead.
Posted on Dec 06, 2012
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
The printer shows LSU error, When i Turn it of after 2 or more hour I can print max 3 copies and then the same error appier (LSU error).
Hello my friend this is Laser Scanner Unit error and this is probably cause if the polygon motor in the LSU does not rotate.The LSU’s laser beam is
functioning properly.You can try unplugging the machine for 3 minutes and plugging back in before you do anything else.If this does not fix it you will need to have it serviced.
Feb 03, 2010 | Samsung Office Equipment & Supplies
Not able to print. printer pop up says Lsu error
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Jan 14, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
MY samsung scx-4521F LSU ERROR. HOW TO RESET THE PROBLEM
No reset will work, it is detecting the Laser Scanner Unit is not operating correctly and it is a replacement unit (LSU).. the lsu is a high speed motor with a many sided mirror attached spinning at very high speed (you can hear the whine in lasers of the spin), the motors wear out and cant spin fast enough yo spread the light and need to be replaced... then your error will clear
Nov 07, 2009 | Office Equipment & Supplies
LSU error code
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Sep 16, 2008 | Office Equipment & Supplies
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Machine does not copy
LSU Error occurs when your printer printhead is damaged. Change your printer printhead, the printer will be ok.
Aug 25, 2007 | Dell 1600n All-In-One Laser Printer
Lexmark X215 MFP All-In-One Laser Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
