Question about HP Pavilion dv4000 Notebook
HP dv4000 not turning on.
My dv4000 is having difficulty turning on. It turns on using the "QuickPlay" features without any issue. However, if I completely shut it down, it may or may not turn on again when I come back to it. Sometimes it takes one push of the power button, sometimes thirty. I have experimented with taking the battery out, etc. and there seems to be no effect one way or the other. Any ideas? This is a refurb I bought in 2006. Am I out of luck?
    Sergeant:
    Champion:
  • 341 Answers
Try removing out the battery and disconnect the power supply for a minute or two. this would reset whatever memory there is
Posted on Jan 12, 2009
I have a problem in using my webcam,its indicated that i need to turn it on.
You need a program like QuickPlay or Muvee Autoproducer to activate the webcam. When in Quickplay, go to the bottom of the screen, select the icon with a camera, and then choose the device from the left-hand menu.
Press the QuickPlay button (normally located near the display) on the notebook PC to open the QuickPlay application.
Alternately, click Start , type QuickPlay in the search field, and select QuickPlay when it becomes available to open the QuickPlay application.
Click the Video icon, and double-click HP webcam in the Source column.
The input from the webcam displays on the screen
Jan 03, 2011 | HP Pavilion dv6000z Notebook
When you switch the laptop on the blue lights on the keybord is on for a few minutes before switched off, but the screen stays black. When you touch over the blue light keys it's turn automatic on? HP...
The touch buttons are there so you can turn your laptop on into the Quickplay feature without having to load into Windows. So basically if you just want to use it for multimedia. If you was to press power button, these will just load straight into Windows. It is meant to do this. If you are saying that the screen doesnt come on when you turn the laptop on and are basically saying that the laptop doesnt boot at all and is just a blank screen, then it is very very likely you have a motherboard failure. Contact HP to see if they have still covered your laptop with warranty as this is a known issue on these laptops and some warranty had been extended
Jul 22, 2010 | HP Pavilion dv6000z Notebook
HP DV4000 laptop turns on and off without loading
i think it's the power ac inside ur motherboard ,u have to change it ,and u can try to install a fresh copy of windows before that.
Nov 13, 2009 | HP Pavilion dv4000 Notebook
HP Quickplay / Computer shuts down into hiberating mode
I don't understand the problem...
The unit shuts down or goes into hibernation when you use the quickplay program.??
I don't know which switch you are in re: to. ??
Anyway, if the unit has a software issue, I would remove the quickplay and re-load the latest version 3.7 or 8. Quickplay is nolonger ava. on there new units and they may discontinue it before long.
Have have to do a complete un-install before re-loading the newer version.
Good luck
Aug 26, 2009 | HP Pavilion dv4000 Notebook
HP laptop stuck in quickplay mode
When Quickplay start try pressing ALT+F4
Apr 12, 2009 | HP Pavilion dv4000 Notebook
Hello, since 1-2 months I bought a new HP Pavilion dv7 Entertainement Laptop. I re-installed vista because I didn't liked the features which were on this Laptop. Then after I installed Vista I remembered...
You need to download the quickplay software here:
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
If the button still does not work, you need to do a hardware reset of the buttons. This is done by unplugging the power supply with the laptop off. Press the power on, then pull the battery as soon as the laptop starts to turn on. Put the battery back in and plug in the power supply and power on the laptop.
Jan 04, 2009 | HP Pavilion dv4000 Notebook
Booting
dear one
you have already used the HP Operating CD to set up your hard drive (and formatted your hard drive, and installed XP, and installed the drivers, and really don't want to do that again), you can still “fix” the partitions - as long as you have the space for Quickplay outside the XP partition.
1. Boot from you HP operating system disk.
2. Press ENTER to set up Windows XP
3. Press F8 to accept License Agreement
4. With your XP partition highlighted (it’s usually C:) press Esc.
5. Make sure you have at least 250MB of unpartitioned space after your XP partition. (If you don’t, you probably have to delete XP and start all over.) I had to delete the 204 MB partition I created in the first place.
6. Once you have your XP partition and at least 250 MB of unpartitioned space, press F3 to quit. (Don’t mess with the XP partition!)
7. Press F3 again.
8. Remove your HP operating system disk.
9. If you’re really fast, you can stick your Quickplay disk in before it reboots. Otherwise, let XP load, put in your Quickplay disk, and restart.
10. Quickplay should load successfully.
11. Note that when this is done, Quickplay will actually only use 204 MB of the space after your XP partition. It just needs more than that to actually run I guess.
oke
cropp
Mar 15, 2008 | HP Pavilion dv4000 Notebook
Laptop stuck in quickplay mode
if you click on ctrl/alt/delete at same time you should get the task manager and choose the shutdown mode or find the quickplay option and end the process too..
you can also just hold down your power button until it turns off but reboot it in safe mode first then boot up again.. hope this helps..d
Feb 22, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
