Question about HP DeskJet F4280 All In One Printer InkJet
Can a hp 56 ink cartridge be substutited for a 60 hp black ink cartridge
No, it cannot. I tested it on an HP DeskJet F2430. The HP56
will not fit in the HP60 carrier.
Posted on Jul 12, 2013
Bubbabear64
  • 2794 Answers
SOURCE: How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Posted on Jun 13, 2008
yooperbud
  • 8637 Answers
SOURCE: Which HP printers use #56 & 57 cartridges ?
Fits Models: Deskjet 450cbi ... 1350 PSC ( 57 56 HP C6657AN Ph C6656AN 57 56 HP C6657AN Ph C6656AN 57 56 HP ....
Hope this helps. Bud
Posted on Jan 25, 2009
  • 21 Answers
SOURCE: How to reset the ink level for a HP 60 ink cartridge
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Posted on Jul 06, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
  • 241 Answers
SOURCE: Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
Posted on May 28, 2010
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Ink name
Heres the link that lets you know the compatible ink for this printer
Supplies for your Officejet 6110
Cartridges, paper, support and specs for your product
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=Q1638A&aoid=5504&lang=en&cc=us
HP 56/57 Black/Color Combo
Hope I help you a bit
Mar 28, 2011 | HP OfficeJet 6110 All-In-One InkJet...
What number is the ink cartridge
The ink cartridges for the 1200 Series can be either the high capacity HP 56 Black (C6656A) and HP 57 Tri-color (C6657A) or the low capacity HP 27 Black (C8727A) and HP 28 Tri-color (C8728A).
I hope this helps.
Nov 17, 2010 | HP PSC 1210 All-In-One InkJet Printer
New HP 56 cartridge prints green
hello, are you sure its green, since this is a black in cart, only thing i can think of is machine not printing black , and the color ink cartridge is contaminated, this would be due to the docking area for the cartridge, on the left side of machine, there are 2 black rubber cups that the ink cartridges move over to seal. sometimes these cups have residual ink, which will contaminate the new inks. clean these black cups, and replace inks
Sep 24, 2010 | HP PSC 1210 All-In-One InkJet Printer
Installed new hp black cartridge 56 ink but won't print
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
Ink cartridge 56 and 58
the printer itself recognizes cartridges
hp 57 print cartridge
hp 58 photo inkjet cartridge
and hp 28 inkjet print cartridge
any other cartridges will be of no use for this specific printer
Oct 31, 2009 | HP DeskJet 5550 InkJet Printer
HP7660 Photosmart Printer
It comes with HP #57 (C6657 A)—Tri-color print cartridge and HP #56 (C6656A)—Black print cartridge and the 56 must always be in there (the black one) but acceptable replacements for the color one are as follows: HP #58 (C6658A)—Photo print cartridge I suggest for the best photos use 58 and 56.
Feb 28, 2009 | HP PhotoSmart 7660 InkJet Printer
I have been given a psc 1310, without an instruction manual and without any ink cartridges.The diagram inside the machine shows 5 different numbered cartridges which the machine uses, 27,28,56,57 and 58. I...
Hello.
HP 27 - Black Ink (approx 220 pages)
HP 28 - Color Ink (approx 190 pages)
HP 56 - Black Ink (approx 450 pages)
HP 57 - Color Ink (approx 400 pages)
HP 58 - Photo Ink Cartridge (approx 140 4x6 photo prints)
Hope that helps!
Jun 07, 2008 | HP Office Equipment & Supplies
Replacing HP 56 Black ink cartridge
Turn off the printer for bout 60 seconds, turn back on and when it tries to initialise hold the set-up and options keys - worked fine for me but I don't know why. Hope it works for you.
Nov 02, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
217 people viewed this question
Seeker5211
Seeker5211
