Question about LG LRSC-26922 Side by Side Refrigerator
LG Refrigerator - I need to remove the ice disp.
I need to remove the ice disp and replace the ice funnel. How do you open up this disp box?
  • djaeger5 Jun 01, 2009
    This help made it very easy.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Posted on Jan 12, 2009
How to replace LG LFX21976ST water valve
follow 1/4 inch water line where it enters fridge panel water solonoid valve is behind it
Dec 30, 2015 | LG LFX21976ST 3 Door French Door...
Tip
Water in the freezer compartment
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and embedding it in a block of ice, as well as puddling-up on the bottom of the freezer and eventually blocking the door from closing properly. Because the water seemed to be covering a wider area than you would expect from a blocked defroster drain I didn't believe that my problem was covered by the other FixYa recomendations -and it turned out I was right.
The problem turned out to be that the "funnel" that the water flows through to fill up the ice tray was blocked by a solid piece of ice. When the icemaker would call for more water it would flow down the clear tube (with the open slots on the top) hit the ice and spray/overflow in to the freezer compartment.
The solution was obviously to pop this ice out, but that did require me to remove the icemaker from the wall of the freezer compartment. To do this you
  • remove one screw from the bracket on the bottom of the icemaker
  • Slide the icemaker up and slip it off of the two screws with rubber grommets on them.
By the time I got to that stage I had already removed the basket from the main drawer and removed the pull out tray/basket from the drawer pulls (by simply lifting the plastic tab on the right side and lowering the plastic tab on teh left side). I am not sure if you can remove the icemaker without this step, but I believe so.
Also, if you want to entirely remove the icemaker from the freezer there is only one plug with wiring to undo. As I mentioned above, the water hose doesn't not connect to the icemaker, it ends above the "funnel" and the water drops in. So removal is much simpler than you might expect.
As for the cause of the ice block, I am not sure but I believe it was either because the ice maker made too much ise one time and some cubes could not pop out. When additional water entered the funnel it didn't flow in to the ice tray, backed up, and froze in the funnel. The other thought is that when the door was not closed properly while our grandparents were visiting, the ice melted and subsequently re-froze causing the problem.
on Dec 15, 2007 | LG LFD25860
The ice box on the ice dispenser appears to be clogged so ice cannot be dispensed on either setting (chunk or crushed). How does one remove the ice box front to look inside?
Hello there,
For you to be able to remove the ice maker from the refrigerator, you will have to get a screwdriver and a work glove, then you follow the steps below:
  1. Pull the LG refrigerator away from the wall and unplug the electrical cord.
  2. Shut off the water supply valve to the ice maker by twisting the knob clockwise. The valve is built into the metal or plastic tube that feeds water to the ice maker at the back of the appliance.
  3. Open the freezer door and remove the ice bucket below the ice maker. Set the bucket in the sink for the ice to melt.
  4. Lift the white plastic housing off the ice maker and set aside.
  5. Remove the screws that connect the ice maker assembly to the inside back of the freezer, using a screwdriver and work gloves to protect your hands.
  6. Push up on the ice maker from below to release the mechanism.
  7. Disconnect the wire plug that connects the ice maker to the back of the freezer and remove the entire assembly.
  8. When you are through with what ever you want to do with the ice maker.
  9. Reconnect the LG refrigerator power cord and slide the appliance back to its original position.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | LG Refrigerators
Ice maker not working no water but the water in door disp.works
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
lkj;fds
Nov 02, 2009 | LG LMX25981ST Stainless Steel Bottom...
LG refrigerator - Need help replacing a part in the door.
How to install part ac110-115v for lg refrigerator
Jul 10, 2009 | LG Refrigerators
Water dispenser on GE side by side not working. what should the refrigerator and freezer settings be? Can that be the problem?
Dispenser controls on any refrigerator actuate one of two things. Ice disp, or water disp. If the IM is not working also, then H20 valve is bad. If just the H20 disp feature isn't working in the door, try this: remove food and unplug unit for 24 hours. Then, plug back in and resume normal operation. If all checks ok, you have a frozen water tank, or frozen water line. Fix: on certain model ref's, there is a water tank service flash where an antifreeze insulation kit should be installed, contact Sears or your retailer for this information. On others, this is simply a freeze up caused by lack of H20 usage or temps in ref/freezer set too low. If this does not fix the water supply, and you still have ice production after 2-5 hours after restarting the ref, remove the dispenser cover and test the water supply actuator switch for continuity. of open after drepression, replace switch. If switch checks ok, then replace water valve as on side of the solonoid valve assy is not functioning. In rare cases, you may have to check or replace the wiring harness. This can be tested only after elimenating the disp switch test, and calling for H20 from the disp, voltage at the disp wires to the H20 valve, but no voltage recieved at the h20 valve, or by an ohm reading of the wires.
Jun 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
Apr 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Lg lfx25960 Ice Dispenser
I had the exact same problem on my LG LRSC26940 and was able to fix it fairly easily. First remove the Ice Funnel by pulling down on it. Then remove the entire dispenser panel by getting your fingernails underneath and pulling out. Disconnect the electrical connecter to the front panel PCB. Remove the 4 screws attaching the bracket that the Ice Funnel connects to. This exposes the solenoid that opens the Ice Door flapper. In my case, the electrical connections to this solenoid were bad. I simply scraped the spade terminals on the solenoid off with a screwdriver and crimped the connectors with a pliers. I put it all back together and it is working fine now.
Dec 12, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LRSC-26922 Side by Side Refrigerator Logo
619 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
