Question about Fedders A7DH45B2A Dehumidifier
Need Fedders A7DH45B2A hose adapter
Lost hose adapter...unsuccessful calling and searching online...please advise...thank you
jj505
  • 195 Answers
SOURCE: Lost instruction booklet
Copy Paste to browser:
http://www.appliancefactoryparts.com/dehumidifiers/helpcenter/ownersmanuals/fedders/
your manuelis here
Posted on Mar 12, 2009
jj505
  • 195 Answers
SOURCE: NEED WATER TANK
Might try Manual @
Also web site has parts to order
Posted on Mar 16, 2009
localwonder
  • 6784 Answers
SOURCE: console does not light up after plugging unit in
Check the power cord for rips of loosness where it enters the unit. if the power cored is fine, this will usually be the result of a power supply board failure. you should replace the power board in this case. the original board is unable to process the AC current at this time.
Posted on May 28, 2009
  • 80 Answers
SOURCE: The coils are freexing up. How can i fix this?
Make sure your coils are clean and free of restrictions and that the fan is running. If this is ok, then it is probably a leak in the system resulting in low charge. Cost of new dehumidifier will be cheaper than having it repaired.
Posted on Oct 03, 2009
freetek
  • 5568 Answers
SOURCE: My Fedders A7DH45B2A dehumidifier (about 4 yrs
> fuse embedded in the outlet (?)
Not a common arrangement so I believe you have it plugged into a 'Ground Fault Interrupter' (GFI) that is a protective device to prevent us from being shocked or killed by lethal currents in case of an electrical path that shouldn't be there.
These function by comparing the current flow in the hot and neutral lines. If there is a slight difference between the two currents, it will interrupt the AC line and will have to be reset (no fuse, just a button) to restore power to the outlet.
Dehumidifiers are an excellent place for current paths that can create this imbalance; moisture and a path to ground which is the third pin on the AC plug. That ground is attached to any metallic parts inside the unit and you likely have some current flowing from the hot side of the line to some exposed, grounded metal that is creating the imbalance.
To verify this, you will need a plug adapter for adapting the three contact plug to a two contact plug. Any hardware store has these. Disconnect the unit's AC plug, plug it into the adapter and then plug that into the AC outlet you are using.
NOTE: If there is electrical leakage inside your dehumidifier, this will constitute a shock hazard! Do not touch anything metallic on the outside of the unit! Once you have seen the unit run without turning off for a day or two, pull the AC plug from the wall, do not touch the unit to turn it on or off. It probably isn't deadly but don't take any chances.
If running it this way works, I wouldn't trust the unit around a small child or anyone with a heart condition and to me, it means the product is defective and should be junked.
Posted on Apr 06, 2010
Where can I buy a new float assembly?
Unfortunately, the entire float assembly (Part # CRCDFD5404-010) is no longer available and their are no interchangeable substitutions.In lieu of that, if you can hook it up to a hose for continual drainage, you wont need the float assembly.
Hope this helps and thanks for choosing FixYa.
Jul 27, 2011 | Fedders A7DH45B2A Dehumidifier
We have to change the fa.,How it cost and where i can by one in Quebec City. Model A6DH65B2A.Thanks
If it's just the fan blade # CRCFD5303-010, you're in luck. It's available from the following link.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=281964&modelsID=114658
If it's the fan motor you're after. They are no longer available. As Fedders has been out of business for several years and many of the parts are no longer available.
I hope this helped you and thanks for choosing FixYa.
Jul 25, 2011 | Fedders A7DH45B2A Dehumidifier
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
Coil is freezing up.rusted coil sensor bracket. i need a new freeze switch sensor for the front coil. i guess it turns the compressor on and off so the coil doesn't freeze solid. can't find the...
Buck, as you seem to be aware, Fedders no longer exist as the Fedders you may have been familiar with 8 years ago. Finding manuals and parts, is like looking for a needle in a hay stack. However, the new company Airwell-Fedders may be able to help you. There Customer Support Dept 866-829-2440, is who you need to contact.
There is one other possible source, as some parts are interchangeable. Appliance Factory Parts
http://www.appliancefactoryparts.com/airconditioners/fedders/ does carry some of the older Fedders Parts, as well as Maytag. So, that may be worth a try.
Hope this helps you find the parts you need. Good luck and please let me know how it worked out for you. Thanks.
Jun 11, 2011 | Fedders A7DH45B2A Dehumidifier
Fan blew apart.....need a new one.
You can purchase them directly online from Fedders or from Sears Parts Central. Fedders makes dehumidifiers for Sears under the name Kenmore.
Apr 25, 2011 | Fedders A7DH45B2A Dehumidifier
How to hook up a drain tube to the pan in the dehumidifer. Do I need to take out the float shutoff?
No, it is not necessary to remove the float shutoff. As water will be constantly draining from the unit, when the hose is connected.
Hope this helped you.
Mar 14, 2011 | Fedders A7DH45B2A Dehumidifier
The coils are freexing up. How can i fix this? fedders dehumidifier a7dh45b2a
Oct 03, 2009 | Fedders A7DH45B2A Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
42 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
