Question about HP Color LaserJet 8550 Printer
HP color laserjet 8550 output is very light (color or B&W) Help!
I was in the middle of printing a run or 350 11x17 Black and white prints on 24Lb bond when halfway through the output went from rich black to a ghost of gray. Have tried printing all different types of paper, new toner, new drum, new transfer drum, new fuser. always the same. Please help me out if any one has an idea. Thanks, Ty
  • HP Master
  • 685 Answers
Have you tried to clean the heads on it?
Posted on May 28, 2013
3 Suggested Answers
SOURCE: Hp color laserjet cp1215 is laying a shadow double
Press Menu button. Then press the <Left> scroll button and <Cancel> button simultaneously. This will take you to the secondory service menu. Press the menu button and select secondary service. Scroll through the menu item and you will see <Clean belt> option. Select it and press select again. This will clean the belt for you. Do it may be two or three times. This will solve your problem.
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: hp color laserjet cm 1312 window 7 driver
It sounds like you downloaded the PCL Universal Driver. Try the full solution driver or the PostScript Universal Driver. Both allow color prints.
Posted on Oct 19, 2010
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
How to set hp color laserjet cm 1017 mfp to print black and white
Open the Printers Properties, settings, select your print preference.
Jan 01, 2013 | HP Color LaserJet 2600n Printer
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
I have an hp 2600n and a ibook 4g. yellow cartridge is empty and orange light is blinking. have printer settings to black & white, but won't print. help!
Regardless of whether you have printer set to print in black and white, these models will not function without usuable cartridges in all slots.
May 14, 2011 | HP Color LaserJet 2600n Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Hp color laserjet 2840 - prints one page in color, next in black &amp; white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Hp color laserjet cm 1312 window 7 driver
Mar 15, 2010 | HP Laserjet CM 1312NFI Color Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP 8550 not printing
Disconnect your network cable and printer's hard drive and then power on. Its possible there is a stuck job somewhere.
If that doesn't work, believe or not it could be the fuser.
Jun 02, 2009 | HP Color LaserJet 8550 Printer
HP Color LaserJet 8550 Printer Logo
Seeker5211
Seeker5211
