Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Wavy diagonal lines only with component cables, not hdmi
I've got a mit's WD-62725, recently I stared getting these diagonal lines sort of "oscillating" or cascading, mainly visible on large backgrounds of solid colors like the grass on a football field or a blue screen behind a news anchor. I thought it might be a bad cable connection ( I'm using a cable box not a card ) but if I switch my input from component cables to the HDMI input the problem goes away. The bad thing is, I like the picture much better through the component cables. I tried switching my cables from the " input-DTV" to the "component 1 " input, same problem. If I have a bad cable connection somewhere, wouldn't the HDMI also give me the same distortion ?...thanks for any help, mike
  • ric noel Feb 06, 2009
    Same problem. Please help
  • Matt Fl Mar 20, 2009
    I have the same TV and I'm experiencing the same problem with "wavy lines". I experience the problem with every device that is connected using the component cables (dvd player, game consoles, etc.). Only the HDMI input gives a clear picture.
  • 87 Answers
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
Posted on Apr 12, 2009
Picture Problem
Model is Mitsubishi WD-62725?
The other question is does it do it on tuner and REAR inputs?
Mar 23, 2012 | Mitsubishi WD-62725 62" Rear Projection...
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
The picture on my Mitsubishi WD62725 is starting to show some wavy lines and snow. We had a repairman come and he said that it needs a new chassis which would run around $550 and he said that it was not...
If the set is 6 years old I would not put $550 into it, but a new 60-65 DLP should only run you from 1200-1800. If you check around you will find alot of Mits DLPs on the internet for even less.
Jan 08, 2011 | Mitsubishi WD-62725 62" Rear Projection...
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Ws65613
how much you pay for the solution?? login and find out!
Jun 04, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mits 65" wont power on
set could have a short and be in shut-down mode ...making just a blinking green light on the front.
remember your standby circuit is always on waiting for a remote command and can be damaged by surges in the line from storms.
please add a surge protector in future after you found the failure.
May 11, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Purple lines moving diagonally on screen
This happened to me last year with the same set. Had it repaired - they replaced the "PCB Formatter" board and the problem was solved. But unfortunately, less than a year later, the problem has coem back. Good luck!
Oct 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
New bulb
If you have no video or OSD then:Suspect the FMT PCB part # 930B924002.
Aug 11, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
530 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
