Question about Cadillac 2012 SRX Luxury AWD
How do i change mph to kph on 2012 cadillac srx
How to change speedometer from mph to kph
SOURCE: Speedometer reads in KPH, can this be changed?
Go into setup menu in the DIC til you see unit measure! Then select unit measure and everything will be back to normal. One is for kph and celcius, Liter/100km, fuel liter used etc and the other one is for mph, farhenheits, mpg, fuel gallon used etc.
Posted on Oct 03, 2008
  • 3 Answers
SOURCE: Replacing front turn signal bulb on 2006 Cadillac SRX
wow i feel sorry for you because Cadillac designed this bulb to be a don't get to bulb but OK here's what you do take the bottom cover off or skid plastic panel under neath the front end theirs little plastic clips holding it on just get come dikes and don't cut them but just use it to help pull them out. after you get that off use a flash light and locate your light housing you should see two screws holding the house in i think those screws are 8mm i cant remember remove those two screws and be careful the metal from the bumper cuts you pull the light housing out and remove all the screws around the housing and open the housing up replace the bulb and make sure your contact to the bulbs clean and then reassemble the way you took apart. if you cant get it well then best bet is take it somewhere i know Cadillac charges an arm and a leg so you can go somewhere else.
Posted on Jan 25, 2009
techbuster
  • 5081 Answers
SOURCE: rear liscese plate bulbs on 05 cadillac srx
First you have to take out the one and only screw in the rear hatch door - it's where the hand pull down is you use to close the hatch.
Then you have to pop all the plastic clips all the way around the plastic door panel, trying not to pull them out from the frame . If you do pull out the white plastic plugs from the frame you better make certain you take them off the plastic housing and insert them back into their frame holes - or you will never get the housing back on.
Once you have the housing loose disconnect the inside tail gate light wire to remove the whole thing. Then you have to remove 7 to 8 nuts from the back of entire License plate, back up bulb housing using a deep socket to get in there. Work it loose from the rear of the car and it will come out just enough to work on the lights.
This is tricky since the screw mounts don't give you much room to work with.
Once you have the license plate and back up bulb frame loose you will see the two housings for the license plate bulbs on top.
Slide out the license plate bulb lens and twist the bulb connection to remove the bulbs.
Replace both of them - you don't want to do this again in a month when the other one blows.
OPTIONAL:
Once you take out the bulbs you might see that the housing is melted where the bulb wanted to burn through. Drill two small holes one is each end of the housing before I put everything back together to release some of the heat.
Reverse the whole process to put everything back together. It's not easy.
Make sure you insert the cables through the opening for the hatch handle or it will kink and not work properly.
The bulbs come in a two pack of cost $4.95 .
Posted on Nov 24, 2009
SOURCE: Changing fuel filter on 2004 Cadillac SRX
If you go to the auto parts store they should have a fuel line disconnect tool that has a 5/16ths end an a 3/8ths end. The tool is shaped like an X. Before you start you need to pull the fuel pump fuse under the front of the REAR passenger side seat while the car is running and let it stall. it will release the built up pressure. This is important unless you want gas to spray every where. Then take the tool and start with the end of the filter with two lines. Place the appropriate end of the tool over the smallest inlet, push the tool in then pull the line towards the filter and then push the line away and it should disconnect. Do the same with line above. Then you can use the two appropriate size wrenches to disconnect the outlet end. reconnecting the new filter is simple just make sure your quick connect lines click in all the way and you tighten the outlet line well, I think its like 22 or 25 ft/lbs.
Posted on Dec 15, 2009
  • 396 Answers
SOURCE: Wiring diagram for 2009 Cadillac SRX
Try your dealer parts counter.
Posted on Jan 16, 2010
How often do your fuel injection cleaned on a 2012 Cadillac Srx
If you notice a power decrease or performance issues, but I recommend changing the fuel filter as a clogged filter can mimic bad or poorly performing injectors, try some Lucas fuel injector cleaner, and why you are at the parts store have them scan the cars on board computer, most do it free of charge and only takes a few minutes.
back to the filter, I change mine at least once a year. I don't care what the owners manual says ! locate filter here 2012 Cadillac Srx Google Search WIX filters are a better choice.
Mar 04, 2015 | Cadillac Cars & Trucks
Need to replace speed dial to convert from mph to kph
I would have it done there. They can give the car a good German tuneup and get it Autobahn ready.
Nov 26, 2013 | Mercedes-Benz C-Class Cars & Trucks
How i can change mph to kmh
Anon, Remove ground on battery with ign still on to drain all power...now turn ign off, attach ground press hold lap timer button the clocks will do a cycle all way round, then the bike will flash mph kph mph kph 10 times in this time when its on mph release the lap timer button, after this bike will now read mph.
Jun 18, 2013 | 2010 Derbi GPR 125 4T 4V
KPH to MPH speedo display
Hi, Dan for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How to change from kph to mph raptor 700
http://www.motorcycle.loc8apart.co.uk/nav-mc/bike-part/Yamaha/BT-1100-Bulldog/Speedometers.php
Yamaha BT1100 2002 Service Manual
OEM parts for Yamaha
YAMAHA BT1100 Owner Manual
Jan 27, 2013 | 2006 Yamaha BT 1100 Bulldog
I have a 2007 Bonneville purchased in Switz but now registering in the UK. The speedometer is in KPH and must read MPH - can I just replace the KPH faceplate with an MPH faceplate or do I have to replace...
Hi. I have a 2006 Bonneville which needs changing to K.P.H. as I have just moved to France. I also have to change the headlight lense, how do you fancy doing a straight swop. My speedo has nearly 10,000 miles on the odometer
May 09, 2012 | 2007 Triumph Triumph Bonneville
My 95 sables digital speedometer is reading kph how do I Change it back to mph
most have a dial or button on the cluster , for mph and kph , if its a digital dash the owners manual should have it in appendix under speedometer , last resort call the dealer with youre vin number located on left hand corner of dashboard behind windshield
Jan 28, 2012 | 1995 Mercury Sable
Speedometer isnt reading right....EX: if im going 40 the speedometer says im going 65
From the sounds of it the vehicle computer was switched from mph to kph. You should be able to change this back using the driver information center located above your stereo under your settings options. 40mph=64.4 kph. If you have your owners manual available may want to consult that how to completely change it back.
Mar 08, 2011 | 2004 Pontiac Grand Prix
Speedometer is on kph and how do i change it to mph
Press "A" buton for 5 seconds, read out ill flash. Then press button "B" this will now change to mph. Re-press button "A" agin for 5 seconds nd the diplay will return o your default screen.
May 11, 2009 | 2000 Aprilia RSV Mille SP
Aug 11, 2008 | 2005 Cadillac CTS
Cadillac 2012 SRX Luxury AWD Logo
Top Cadillac GPS Experts
J.D. Browning
J.D. Browning
syspro
Todd Arndt
Todd Arndt
Are you a Cadillac GPS Expert? Answer questions, earn points and help others
