Question about Cameras
What is a good way to hold the lid on my go pro case for te mean time until I get another one
    New Friend:
You can just use a rubber band to hold everything in place - just like they did here: What is a good way to hold the lid on my go pro ca - 12_4_2012_10_27_01_pm.jpg
I used to fabricate them by cutting old bike inner tubes in 1cm large rings - they work perfectly! ;)
Posted on Dec 04, 2012
WHERE CAN I FIND THE MANUAL FOR THE ARMITRON 40/8284 PRO SPORT WATCH?
hi Robert.
i can not find a manual for this watch,but if you go to this link it should show you step by step on how to set it up.
its not showing your model number so not sure how good it will be to you.
if another window opens on the page just close the popup window down.
Instructions to Set the Time on an Armitron Pro Sports Watch
or try this.
How do you set an armitron pro sport watch? Press the "Mode" button repeatedly until the time display appears on the watch. Hold the "Mode" button until you see the alarm display appear, then release the button. Hold the "Mode" button a second time to enter the time-setting mode.
Instructions to Set the Time on an Armitron Pro Sports Watch ...
https://www.livestrong.com/.../247211-instructions-to-set-the-time-on-an-armitron-pro-s... Search for: How do you set an armitron pro sport watch?
or read up on this link.
MANUAL FOR THE ARMITRON 40 8284 PRO SPORT WATCH Google Search
Nov 29, 2017 | Armitron Watches
Has and F1 fault
HI- The F1 fault means that the Mains Filter board on the bottom pan has detected water, a leak. The only way to stop the fault from constantly running the drain pumps is to unplug the dishwasher or turn off the breaker. You will need to keep the dishwasher off until you get it worked on unfortunately. There are, unfortunately, a few possibilities that can be the cause of this. Most likely it is bad lid motors (the motors that lift and pull down the lid to seal the drawers) or a broken Link Support. This is the plastic assembly that holds all the hoses and wiring out of the way when you open and shut the drawers. A portion of this Link breaks free and gets lodged in between the drawer and the lid causing water to pour out into the lower pan when the unit is running. In this case you will have to have the Link Support and the Lid replaced. The other cause can be someone put really tall plates or a pan in the drawer and the lid couldn't close completely when the cycle started and the water leaked out of the gap between the lid and the drawer.
You'll need to have a Tech out to take a look at it and determine the exact cause. Make sure you use a Authorized F/P tech as these machines are unique. Good luck.
Sep 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to get bobbin thread to come through to the top
On a front loading bobbin the thread must be going over the top to the right clockwise and hanging down. Then take the bobbin case holding it so that the finger like thing is pointing up. Place your bobbin in the case and pull the thread up through the **** on the side until it snaps into the little hole at the top of the ****. Now turn the case around holding on the flat metal flap and wiggle the case in the bobbin case holder in the front of the machine with the finger still straight up and push gently until you hear it snap in place. Turn the hand wheel one complete turn holding the top thread under the presser foot to the left and you will see the thread going down to pick up the bobbin thread. If you have done the correctly and it still isn't picking up the thread then it is most likely a timing problem and should be fixed by a repairman. They have to line everything back up so that the hook on the bobbin case realigns with the needle so the stitches will lock. Usually when the fabric has been pulled too hard bending the needle or it hits the needle plate and gets out of alignment or someone runs over pins while sewing this causes the timing to be off. I hope I have answered your question. It's probably not anything you are doing wrong and was probably done before you got the machine. Let me know what happens or if you need any more help.
Sep 20, 2010 | Euro-Pro 473
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
MFC8860DN SAY'S SCANNER LOCKED?? WHAT'S THE FIX??
Hello my friend.If you open the scanners door under the document cover is one switch that locks and unlocks the scanner.Move it to the position that shows that is unlocked.If this doesnt work it means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This should fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remove the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable . After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp more into the scanning area and repeat until works.
Feb 09, 2010 | Brother MFC-8860DN Printer
Will not reboot, at all. i power it on, the power light comes on, the dvd drive spins a few times and then nothing.. the bios screen wont even show. please help.
try removing the ram from the bottom of the case first and take the disk out. power on the unit. if you get a bios screen there is a good chance you have some bad ram. let me know what you get from there
Jul 12, 2009 | Gateway MT3422 RTL Notebook
Incorrect distance
Bushnell doesn't work on those anymore, but they still have the manual for them. Make sure when you hit a target you don't see a "M" next to it. This means it's reading in meters instead of yards. Hold down the "mode button" until you see "Y" (yards) if this is the case. If not, the unit will need an alignment and bushnell doesn't do them anymore. They will offer you a newer model. The Pinseeker technology is good......They have three models to choose from.
Good Luck!!!!
mtg
Jun 09, 2009 | Bushnell Yardage Pro 500 Rangefinder
Instrutions for casio g600
A --- B Setting the digital time.
C __ D
Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Set time, Date, etc:
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
Good luck,
Techjoel
Jan 06, 2009 | Casio G-Shock G600-1AV Wrist Watch
BROTHER MFC-8840D "Check Scan Lock" error message
I had the same problem. It means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This may fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remover the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable be carefull not to drop the lid, break the cable or the glass bed. After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp farther into the scanning area and repeat. Good Luck
Oct 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
