Question about Logitech Radio Communications
Logitech headset h540 not working properly
Just purchased this headset so the problem started when first used. Left side volume very weak. Using balance controls I have to adjust left channel to 100% and right channel to 15%. This leaves the total volume low. I have used the volume control on the headset to max out the volume but it hasn't helped. The same problem occurs on both Windows 7 and Windows 8 computers.
SOURCE: echo when using the headset
If you are having echo problems while not on a call (you are wearing the headset, it is active, but you are not currently on the phone with anyone), there are 3 ways to counteract this: -When you are done with a call, you can click your Multifunction button on your headset (middle one inbetween the volume controls). -Move the microphone away from your mouth when you are not on a call. -A more permanent solution: decrease the sensitivity of your microphone. To do this, click and hold the increase and decrease volume buttons on your headset ( + & - ) for 3 seconds. Let the buttons up after 3 seconds and push the lower volume button 2 or 3 times. Wait 6 more seconds and it will beep at you. After you have done this, make a call to someone in the office to be sure the sensitivity has not been lowered so much that others can?t hear you.
Posted on Jan 17, 2007
SOURCE: Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Posted on Jan 24, 2009
  • 123 Answers
SOURCE: my left side of this headset is not working
those wires are very fradgile and chaces are they have snapped inside the jacket
it happens mostly when you pull on the wire instead of the jack or the wire gets caught or stretched --is your jack fully inside the connecter? wiggle the wire and if it sound than it is the wire
Posted on Apr 22, 2009
welcomejee
  • 10594 Answers
SOURCE: speaker left/right balance control
This Aiwa audio system has no balance control as its already balanced.
Posted on May 19, 2009
SOURCE: unable to get the controller to work properly
I can't update my controller from the internet
Posted on Jul 23, 2009
Usb Device has Malfunctioned
if that's the case well, contact the store or the manufacturer
May 12, 2013 | Logitech H540 USB Headset
I just purchased this headset plugged it into the
Do you have sound otherwise? The sound to your headset comes from your sound card. You need to ensure the soundcard is properly installed. If it's ok, check there are no checks in the boxes on your audio controller. Right click on the little speaker icon in the system tray and select "Adjust audio properties", Select the "Audio" tab and choose "Sound playback". Clear any checks from the appropriate boxes and set the volume level to suit. Should now work.
Apr 18, 2010 | Logitech ClearChat Stereo Headset Headset
Can i repair the cable on my headset myself. their is a short in the wire and no sound out of the left side Logitech USB with in line volume
problem is lately all the higher end headphones and usb sets use microthin wires. there is fine strands like as thin as a string and woven into it is 2 or 3 micro thin copper strands. it may be possible but very difficult...
Oct 04, 2009 | Logitech Precision Stereo PC Gaming...
Not able to increse volume.The volume controller on my laptop automatically slides down even if I increase it while using the headphone.
your head phone volume controller /speaker/s has been short circuited so please replace /purchase new headphone
thank you
May 24, 2009 | Logitech ClearChat Pro USB Headset
Headset volume adjustment
if connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
Jan 21, 2009 | Logitech Premium Stereo Consumer Headset
Headset volume
ok just tested it and even out of the game it does the same thing.
May 18, 2008 | Logitech 250 Headset
L9 headset
turn up the volume on the left hand sign on ur phone
loook for the code at the back on ur fone and try repairing it..
hopefully it will work :)
May 10, 2008 | Motorola Radio Communications
Logitech clearchat pro headset
hello guys,
you have to update your audio card drives and vista updates should be upto date. then follow following options and you could find the solution there.
http://www.focusmp3recorder.com/images/fmr_vista_13.gif
Jan 15, 2008 | Logitech ClearChat Stereo Headset Headset
Radio Communications Logo
1,281 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
