Question about Lexmark X4530 InkJet Printer
Lexmark only connects to print server
Cannot connect to home network only connects to what seems to be internal print server at "print server 21348A"
  • Official Brand Answer
  • 3,344 Answers
Make sure that you have the right SSID and password for your network. Also, try to powercycle your router and printer. Just unplug the power for about 30 seconds then plug it back in.
If it still doesn't help, try to leave you network open without any password and check if the printer is able to connect. If it does, check if the wireless standard is set to b/g/n. If it is, set it to b/g.
Posted on Dec 10, 2012
SOURCE: Lexmark c510 re-installation problem
Reset the printer engine code.
You can falsh the printer with the USB flash utility form lexmark and reporgram the engine code.
The code is available for download at the lexmark website.
Posted on May 15, 2008
SOURCE: Print server thinks printer is offline
Disconnect from the net and turn off your firewall while trying to install.
Posted on Jul 31, 2008
  • 3 Answers
SOURCE: Lexmark X4850 Wireless wont connect
Had a similar problem with my router, which was a 2WIRE router (furnished by AT&T - I have Uverse). Fixed it by going to the router's GUI (mine is 192.168.1.254), click on "View the home network". On the right side of the resulting screen, there is a section titled "wireless settings". Under that, click on "edit settings". Enter the login information (the default password is on a tag on the router). The next screen is "Configure the Wireless Network". Scroll down to the bottom and click on "Rescan". When I did this, my X4850 miraculously connected and started working.
Rick from Austin
Posted on Aug 25, 2008
CompuGuy44
  • 432 Answers
SOURCE: No wireless printer port for lexmark x4650
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Posted on Feb 03, 2009
SOURCE: Lexmar 4875 Flatbed Wireless printer not connecting to the networ
I know you posted this in May, so have probably given up and bought a new printer by now, but I thought it worth mentioning that I had the same problem exactly (though without the same number of iphones and laptops!).
Buried away in some documentation on the driver CD, is the fact that the X4875 can't communicate with a secure wireless network that uses a TKIP algorithm - it can only handle AES. My router used TKIP out of the box, and I never thought to change is, especially as it's stronger than AES. However, changing it to AES solved the problem.
By the way, if you're using Vista, you may find that you have to run the install package in Windows XP compatibility mode, and then when the install is complete, manually change every .exe under c:\program files\lexmark\.. to run in XP compatibilty mode too. Works for me (Vista Business), but didn't work wirelessly at all before. Good luck,
Chris J.
Posted on Jul 13, 2009
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
I have 2 different magnia sg20 servers. One is in the office and the other one at home. Now I want to access one server from the other network. But as both of them have the same ip, I am blocked. So I...
No. You are on two different networks. Regardless of the hardware. Treat the home server just like any other PC or tablet. Make sure it has a dynamic IP via DHCP from your home router or ISP modem. Then connect via VPN.
You will not be able to network the two servers unless you have right equipment and network configuration. You would have to work with your service provider to obtain static IP's.
Internal IPs are irrelevant, because you can assign them your self internally. That means no one else sees them.
Mar 08, 2013 | Toshiba Magnia SG20 Server
I cannot connect to my 3Com OfficeConnect Wireless (3crwps10075-us) Print Server 3crwps10075
Check you firewalls. Sometimes you will have to allow certain mac addresses or certain ip addresses (may be less secure than the mac address), then change sharing level to full, before things begin to work.
Please post back and let me know if this helps!
Feb 21, 2012 | 3Com OfficeConnect Wireless...
We believe the problem with our LaserJet 5000 GN is the JetDirect 610N network connection on the back. It prints its own internal documents just fine, so we know it's not that. And the network itself seems...
New Part Number is J7934A it is newer version and costs about $75.00 . To test the jet direct, press menu and then information, print the configuration page, if more then 1 sheet comes out 1 will be for the jet direct if this prints there is nothing wrong with the Jet Direct. however if you are printing through the network and you are getting any type of special characters like $%^ it is most likely a driver issue, uninstall the printer and reinstall using PCL 6. You can go to HP's wesite for driver support. Hope this helps.
Jan 03, 2011 | HP JetDirect 610N Print Server
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Lexmark X4530 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
