Question about Echo Garden
How do I remove and clean fuel filter on Echo Blower model PB-500h
    Problem Solver:
  • 13 Answers
Remove he hose attached to the filter inside the tank. pull filter out and rinse with some clean gas then blow compresses air after dried and re-install. or just remove old filter from hose in tank and replace with new filter and re-install.
Posted on Apr 25, 2014
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 603 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
broman28
SOURCE: echo pb-260l won't rev up under load. like it is
blown moter from bad gas mixture
Posted on Aug 21, 2009
SOURCE: echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Posted on May 30, 2010
SOURCE: I have a Echo PB-260L Blower. It starts fine then
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Posted on Nov 12, 2010
Gas/ oil ratio for pb 500h
What are you asking? I am LP tech.
Aug 25, 2016 | Echo Garden
Echo PB 500H will start and idle but dies under wide open throttle.
turn back on fuel adustment screw for high this will let more gas to carb or rebuild carb
Aug 14, 2014 | Echo Garden
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
I have a Echo leaf blower and I can get it running but then it's cuts off after just a few seconds. It has new plug, air filter and fuel filter. What else could it be?
The carburetor could be dirty and need a good cleaning and you could first remove the fuel pump cover (cover without the vent hole) to the carburetor and look for the small, round, fine-mesh screen. Sometimes it gets covered with dirt and debris and has to be cleaned as it allows the fuel to flow into the metering side of the carburetor.
Dec 04, 2010 | ECHO, Inc. PB-251C Handheld Blower
Echco PB-230LN blower
Try adding some "Seafoam" brand additive to the fuel mixture, that did the trick for mine. Must have been something in the carb and the Seafoam cleaned it out, runs just like the day it came out of the box
Nov 01, 2008 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
116 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
