Question about Refrigerators
How do you clean the condenser in Frigidaire side by side model FRS26R4AW5?
Freezer side is not maintaining foods solid frozen and so I want to clean the condenser as recommended in the manual. The manual does not say how to do it or how to get to it.
  • John Tripp
    John Tripp Dec 05, 2012
    I think I left out the part number for your Adaptive Defrost Control here=> 5303918476 Let me know if you have questions, Thanks JT
  • John Tripp
    The link showingthe defrost heater as part location 14 and 21 is the defrost thermostat is 21 here->http://appliance911seabreeze.com/FRS26R4...
  • Refrigerators Master
  • 4,654 Answers
You first need to see if there is frost building up on the rear panel inside your freezer. This may be a defrost issue so I need you to at the least have a look to see if any frost is building like in this=> PHOTO You may also need to remove the rear panel of your freezer to expose the frost buildup as seen in this=> PHOTO
If you find frost building like the examples I listed the problem will be the Adaptive Defrost Control listed as part location 23 in the photo=> HERE
The adaptive defrost control board can be found here=> FRS26R4AW5 Defrost Control Board
how do you clean the condenser in Frigidaire side  - 12_5_2012_7_13_14_am.jpg
The defrost heater is part location 14 and the defrost thermostat is listed as part location 21 found in the exploded view of the evaporator section=> HERE The next most likely parts to fail are the=> 5303918255 Defrost Heater Assembly
and the=> 53how do you clean the condenser in Frigidaire side - 12_5_2012_7_24_09_am.jpgtat
How to test these parts can be found in the tutorial found on the same pages. Below is a link to=> HVAC Refrigerator Coil Cleaning
I will be here should you have questions, Thanks
Sea Breeze
Posted on Dec 05, 2012
  • 37 Answers
SOURCE: Frigidaire fridge side by side not cooling after cleaning fan
Sounds like you have a bad compressor
Posted on Apr 25, 2009
eagle338
  • 4889 Answers
SOURCE: kenmore 50222000 help me please
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Posted on Oct 19, 2007
  • 1073 Answers
SOURCE: frigidaire frs26zthb3
icemaker is iver filling and running down through the freezer, some of the water runs out into the floor since the door gasket does not provide an water proof seal just an air tight seal
the ice maker can be adjusted, remove the cover off the frount of the icemaker and back the screw on the right side so that the indicator in the middle is twards the minus sign and you need to clear the frozen water out of the freezer drain pan so it can go to the drain pan down at the compressor
it might take a few adjustments on the ice maker to get it right
Posted on Apr 30, 2008
Master_Tech
  • 770 Answers
SOURCE: freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
Posted on May 10, 2008
  • 1218 Answers
SOURCE: Food in refrig crispers freezes. Top of freezer too warm.
Good day,
You are right about it being little or no air circulation. There is a fan motor in the freezer, which you can access by removing the rear panel of the freezer panel.
That's the good news. The bad news it is a DC variable speed motor controlled thru a thermistor and powered from the motherboard located in the back wall of the refrigerator.
You can remove and take the motor to an appliance parts house that deals in GE parts. If they determine the motor is bad, then you could effect a repair.
If not the machine is too complex, and some parts so expensive that repair is best left to a GE qualified pro.
Posted on Nov 09, 2009
Why on my model FRS6LR5EW3 freezer side is working maintains ice but fresh food side is not working, no light, no fan??
Good Morning Friend,
I understand the freezer portion is working on your Frigidaire refrigerator, model# FRS6LR5EW3, but your refrigerator does not seem to be as cool as it should, due to the fan not working. I also see that the light is not working, even after changing it out. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if the light is on. Also, listen for the fan to run and give the refrigerator portion of your appliance 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Freezer is running constantly. ice crystals formed on outside of packaged foods. food is still frozen.
the door was left open,if you find frozen water droplets on the food packages or ice crystals it forms from the warm air coming in,make sure all the packages are pushed in and not hitting the door and you can tilt the fridge back a little so the door will close with a slight push.also check the ice shout door and make sure no air is leaking through it,you'll know you'll see all ice around it.you can check the condenser coil and condenser fan to see if it needs to be vacuumed,the machine will run longer if the coil is clogged with dust or if the fan isn't blowing,the coil should be cleaned every 6 to 12 months.hope this helps but it sounds like the freezer door was left open.
Sep 06, 2011 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire side by side freezer not keeping food frozen
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
I have a Frigidaire Upright Freezer making strange noise.
Check the condenser fan,m sounds like the bearings are failing.
Good Luck,
Gilsh
Nov 28, 2009 | Refrigerators
My ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
