Question about Electric Mobility Health & Beauty
Need battery charger for Rascal 600 scooter - Electric Mobility Health & Beauty
  • Electric Mob... Master
  • 1,263 Answers
Hi, GOTO the following website , they sell you a 5 amps one for 30 including postage.
Posted on Dec 06, 2012
gewiz
  • 1263 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
  • 177 Answers
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Posted on Jul 07, 2010
  • 313 Answers
SOURCE: we need a manual to repair donated scooters
Rascal's are made by Electric mobility and are based in Dorset in the UK. Web link http://www.electricmobility.co.uk/Default.aspx Go to their sit to download manuals and get information.
Jazzy's are made by Pride mobility based in Oxfordshire in the UK. Web link http://www.pride-mobility.co.uk/ click on Resource Center at the top of the page.
Good luck.
Posted on Aug 09, 2010
SOURCE: i have a 245 Rascal Scooter. I need to know if I
most rascal 235 and 245 scooters come equiped with power seat height control. you turn the key to the left and then the throttle lever becomes the seat height controller. the seat motor is ditectly uuder front of seat post. if it will not run follow wires to see that they are plugged up good.
Posted on Oct 03, 2010
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
Onboard battery charger quit working.
hi William, there is a fuse located until the rear cover please check that's okay , if so then sadly the charger unit has failed, i can supply you with a normal charger lead that you fit to the batteries and will allow you to use a normal three pin charger, a lot cheaper than a replacement unit ..
Regards
Rob
Oct 05, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
I have a rascal and put new batteries in it and it seems they will not charge up what could be the problem?
Hi Chris,,,, Now lets get the silly question out of the way first, have you tried another charger ?
IS it a built in charger ?
Remember a bad charger == Bad batteries...
the lead that goes from the chagrer socket to the batteries via the controller are most likely adding resistance that the charger does not like ...
Regards
Robi
Aug 31, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
Wiring schematic rascal 600 24v electric
hi, firstly what controller is fitted (curtis) ? then i can give you a ideal controller wiring schematic but you won't get hold of a Rascal one..
Regards
Rob
www.gewizrepairs.co.uk
Aug 16, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
Need a battery charger for rascal 600t
I recommend the 5 amp Charger. Monster Scooter Parts have them.
Apr 09, 2014 | Electric Mobility Power Electric Scooter...
What kind of chargers can i use for rascal 600
I would recommend the correct automatic charger as you don't want to damage your batteries or have a fire/explosion.
Mar 27, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600 wiering diagram
Hi Carol, I have lots of Rascal answers at my link, also check the Rasca pics, the is a Diagram there. but if you have a specific problem you can post there or here, we will do are best for an answer. Scooter Doctor App
Mar 18, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Health & Beauty Logo
226 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
