Question about Ovens
Finding parts for Rosieres/ Bocuse Oven
L/H and R/H shoulder side trim parts- 93647162 93702652
How to oven roast pork shoulder roast and at what temperature
There are hundreds of internet recipes for pork shoulder (or porkbutt--which is just a couple pieces of pork shoulder that are butted together and tied with string).
roast pork shoulder Google Search
Apr 17, 2016 | Ovens
Rosieres 4040DB cooker - Problem with oven doors
hi can you please give me a call re this... I have the same problem on my 4040db and I am keen to know if/how you resolved it, many thanks Simon 07787 511443
Jul 07, 2010 | Ovens
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Having trouble removing my oven from the wall in order to replace the bottom heating element.
What model?    Is it a 'wall-oven'?  If so, many have trim pieces on the sides that cover actual mounting screws.  Also- these units are extremely heavy and require two people to remove/install. Trim pieces are usually held in by screws accessed with door open. Some trim slides up to release. With trim off mounting screws should be visible. Remove these, and unit should be free.Wiring behind unit can also be shorter than most people think, so have something to set it on.  Please acknowledge this posted solution if helpful-  Have more info if needed- Thanks-- Ed
Mar 24, 2010 | GE Ovens
Built-In Oven Buttons Stop Working
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
Email me for some pictures:
schmidtkeith1@yahoo.com
Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
I'm looking for the reference of the fan oven element for Rosieres F142FA 4039343280 oven. Thanks
Dec 02, 2008 | Ovens
Self-Cleaning Cycle Caused Top oven to stop working
I removed the side trim panels, then the control panel. the wiring diagram was behind the control panel.
Sep 03, 2008 | Whirlpool RBD306PD Electric Double Oven
Upper oven locked and control panel is not working
First off this oven sucks. Now to fix the problem replace the Fuse assembly with #4451042 an $11.00 part. SHUT OFF THE POWER AT THE BRAKER PANEL FIRST. Then open the lower oven door and remove the two small screws that hold the side trim pieces, slide them up a bit to remove. At the top of the track remove two more small screws that hold the display panel in-place and lift the cover up and away from the oven. The fuse is inside of a clear plastic tube with a female spade connector at each end of it. replace the failed part and put things back the way that they came off. Next time don't by a Whirlpool.
May 20, 2008 | Whirlpool RBD305PD Electric Double Oven
Microwave oven light - KEMC 307
you ll need to pull unit out to replace bulb, 2 scrws remove side trim of oven, 3 or 4 screws remove trim under micro; above oven, 2 more screws behind that grill will release micro from supportthat should free it up enoug to slide foward 6 or 8 inches( the bulb is ontop of the cavity) good luck!
Feb 25, 2008 | KitchenAid KEMC307 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
