Question about Wahl 8892-002 Kennel Pro Clipper Kit
I took my blade apart on my wahl clipper
I took my blade apart on my wahl pet clippers and cant remember how to line them back up so they will cut again.
  • Anonymous Jan 17, 2009
    My kids dropped my clippers and the inner blade came out. I cant get them back together.. I need to cut their hair!!!
  • FFWIFETRISH Mar 17, 2009
    WHEN i PUT THE RAZOR BACK TOGETHER IT WILL NOT PROPERLY ALIGN AND CUTS THE SKIN INSTEAD OF CLIPPING THE HAIR?
SOURCE: wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Posted on Oct 09, 2007
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Posted on Jul 15, 2008
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
askmannyssha
  • 76 Answers
SOURCE: how do you change blades on Wahl's clippers?
No problem look at your clipper blade, you will see 3 screws remove the screw in the middle ONLY, The clipper blade will come off, replace with new blade put back the middle screw on and tighten.
Posted on Mar 30, 2010
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Wahl clippers
Have you read the instructions and put it together the right way?
Sep 29, 2013 | Wahl Home Grooming Animal Clipper Kit With...
Wahl clippers
Check to see if the blade is moving when turned on. If the blade isn't moving the clipper blade may need to be thoroughly cleaned. If the blade is clean and well lubricated but still not moving you may have blown the motor.
However, if the blade is moving freely when turned on, and the hair/fur is just not being cut (or is cutting raggedly or pulling at the hair/fur) you will need to get the blade sharpened.
May 02, 2013 | Wahl U-Clip Deluxe Home Grooming Pet...
I used my Wahl clippers for my horse a few months ago and one night when i needed to use them the blades will not move, it will just vibrate is it someting with the alignment?
The blades are stuck together because you didn't lubricate them before you put them away. Oil them and force them apart with a knife or screwdriver, use the gap between them at the side.
Feb 28, 2013 | Wahl 9160-210 Corded Basic Pet Clipper Kit...
My clippers are pulling the dog hair instead of cutting, why?
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Nov 24, 2012 | Wahl KM2 Speed Electric Clipper: Two Speed...
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Wahl clippers
Oct 04, 2007 | Health & Beauty
Wahl 8892-002 Kennel Pro Clipper Kit Logo
947 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
