SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
SOURCE: My sportcraft tx 2.5 treadmill does not have the safety key
any round magnet that will fit in the hole will work.
Testimonial: "Thanks a lot..This really helped"
SOURCE: sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
SOURCE: I adjust the speed of my treadmill and it works
the drive belt is slipping under the motor hood
ERR
1 - Motor Movement
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
Clean the sensor, test for open or faulty, tight the connector very well,adjust it, see the diagram attached.
God bless you
