Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Dura Edge 10W, 2.4mm blade for Oster Universal Motor Clipper
I cannot find a replacement blade for the Univeral Motor Clipper. The blade that came with it says "Dura Edge" 10W, 2.4 mm
    Problem Solver:
  • 10 Answers
No problem! Dura Edge is just a fancy name! You can get an Oster or wahl, moser. I work with these every day of my life! Either way, they all fit and work. I work for Shear Ease Ltd. Go to www.sheareaseltd.com they dont have the price for that one on the website but phone them and Colin will give you a price for one and they'll send it out same day.
Posted on Aug 03, 2010
Oster problems. Golden a5 clipper
The blade driving lever is certainly supposed to move, if it isn't then take the cover off and check the cam gear, it's really easy to change it.
Jul 17, 2014 | Oster Golden A5 2-Speed Universal Motor...
I have an Oster Golden A5 2 Speed animal clipper and don't know how to change the blades. I live in Australia so can't go to Oster. How do I do it please and is there a comprehensive Oster Manual? Thanks,...
hi, if you look at the blade while its attatched to your clipper, at the back edge of the blade there is a black metal peice called a Latch push this towards the blade and pull the front edge away from the clipper it will hinge away then you can pull it straight off.
As for an instruction manual if you have no luck contact us and we can send one to you.
Dec 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
How do you put on a blade when you took it off?
There is a picture of an oster clipper in the picture so I assume you are talking about an A5 style blade/clipper. Hold the clipper with the hinge facing you, if the hinge is open, then turn the blade so the blade number is facing up and slide it onto the open hinge, start the clipper and push the blade down to shut it. If the hinge is not open, prize it open with a flat head screwdriver. www.sheaeaseltd.com
Jul 12, 2010 | Oster Golden A5 2-Speed Universal Motor...
Blades fell off oster dog clippers but can't fit them back on. Please help !!
Assuming that you did not damage anything, the blades should go back on easily.
Slide the blade onto the hinged flat 'post'. Turn the clipper on. Fold closed the blade assembly into position against the clipper body.
If this does not ork, you must have damaged something.
Mar 27, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Where do I put the oil in my oster a5
across the blades were they contact each other.  WD40 works fine.
Mar 07, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
192 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
