Question about Brother IntelliFax-4100e Fax
Have a Brother Intellifax 4100E printinng black fuzzy line down one side
After putting in a new high yield toner 2 weeks ago, Brother (not refurb), we are getting a fuzzy black line down the left side of each printed page. Have cleaned it out and everything, but keeps happening. Is it a bad toner, or could it be the drum needs to be replaced?
bowdo
  • 78 Answers
SOURCE: Brother Intellifax 2820 printing problems
If it is on copying it can be a build up of ink on the scanner glass. Open the cover in which the the original is scanned. There will be glass strip that can be cleaned also check the white plate that sits above the scan glass.
If it is recieved faxes and prints as well the problem is going to be the drum has worn out. You have two machines, try interchanging the drums to see if the lines that are present on one machine travels to the next. That way you can see if it is definately the drum. If so change the drums on the machines and they should be fixed.
Posted on Jan 31, 2008
  • 8 Answers
SOURCE: Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
Posted on Jan 04, 2009
leroyal
  • 2120 Answers
SOURCE: change drum soon
Instructions are in the box that the new drum comes in.
Posted on Jan 13, 2009
MalKontent68
  • 748 Answers
SOURCE: Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Posted on Nov 07, 2009
FixinFax
  • 3085 Answers
SOURCE: Our Brother Intellifax 2820 is saying change drum soon
The toner and drum are separate units. Buy one here.
http://www.discounttoneronline.com/mm5/merchant.mvc?Screen=PROD&Store_Code=dto&Product_Code=IJN_BRO-DR350&Attributes=Yes&Quantity=1
Posted on Nov 26, 2009
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
Brother intellifax 4100 e display says to replace toner but cartridge is not empty. Is there a reset for the toner?
There is no reset for the toner. It uses an optical system where light shines through the toner. Shake the cartridge gently left to right to even out the toner and try again.
Jul 01, 2011 | Brother IntelliFax-4100e Fax
How do I replace the toner in my Brother Intellifax 4100? The new toner cartridge just arrived, but this is the first time we have had to replace it.
Open the front of the machine. Lift and pull the whole unit (drum) out. Once you have it out it's pretty simple to remove the old toner from the drum and install the new one.
Jan 04, 2011 | Brother IntelliFax-4100e Fax
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
My intellifax is pirnting all faded on the left side but not the right.
have you tried changing the drum imaging unit? It could either be a toner cartridge problem or the drum unit needing replacement. If it's new toner or new drum and this problem started since changing to the new, you may be able to get a replacement at no charge or a refund.
Hope this helps.
Nov 02, 2009 | Brother IntelliFax-4100e Fax
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Brother intellifax 4100 prints full page all black
Good chance the High voltage power supply is bad. Not worth repairing. A new unit costs about 259.00.
Aug 08, 2006 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-4100e Fax Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
