Question about Optics
Pin point longridge range finder battery cover lost
I lost my battery cover for my longridge pin point range finder and can't find a replacement anywhere, I've sent emails to longridge various times with no response :-(
SOURCE: Battery cover for Laser 800 Rangefinder
Hi!
The model you have is the LASER 800 and it was made in 2000.
To obtain a replacement battery cover, follow this link:
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?&p_faqid=238
Once the page loads, you can choose the option that you think best fits your need - either email, use the knowledge base or simply phone the listed service number to order your part.
Posted on Nov 15, 2007
SOURCE: I lost the cap for the battery on my Bushnell
This happend to me not long ago and I called Busnell North America and they asked me what type of range finder I had and sent me a new one...NO CHARGE!!
Very nice of them and it was shipped out fairly fast as well. Give it a try...(800) 423-3537
Posted on Jun 29, 2009
  • 2976 Answers
SOURCE: need the proper tool for a nikon prostaff range finder
Harbor Freight has a kit that has them in it and most industrial tool supply companies have them. It's a security screw. there are many kits availably with an assortment of bits in them. Drill Master has a 100 piece kit that's pretty cheap. Item#91310
Posted on Oct 29, 2009
Testimonial: "Perfect. Huge Help. Thanks"
SOURCE: Bushnell Yardage Pro 700 Scout Range Finder
I live in london ont
Posted on May 16, 2010
taran_2005
  • 10515 Answers
SOURCE: My golf range finder is not picking up the
The unit needs an alignment. Vibration and dropping the unit is the number one killer of rangefinders.....After a while of using them, (bouncing around in golf carts, cup holders, dropping them on the cart path, or the ground) small prisms start to move inside and decrease the units effective range.... (only able to hit a target at about 150 yards or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment is due. For all you players that think its okay to take off the eyepiece cap.....(bad idea) This is why you see oily looking spots or black spots in the view. Direct sunlight will be magnified and burn the surface of the LCD. Bushnell is good about warranties but, if you take it apart...the warranty is void!!!! So if its 2 years old or less.....(send a copy of the proof of purchase) .send it to them. If you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
THE COST..... $50 for alignment, $15 for LCD, $40 for newer eyepiece that helps deflect direct sunlight (will not prevent thermal burns but, protects for longer periods of time before damage happens) $15 for clean and adjusting. Bushnell's# 800.423.3537
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 12, 2011
Does it need 6mm hard wired cable or can it be used with standard 13amp plug via ring min
hard wired is the normal way ranges are done unless they are gas .then the electric can be lighter gauge
Apr 23, 2016 | Ovens
We can not open the fob to insert the battery.
Sometimes the cover is small and hard to see. You may need to use a safety pin to push on the small release arm to get the cover off.
Mar 25, 2015 | Sharper Image The Wireless Remote Key...
Battery replacement for golf buddy range finder
Ask on Internet , All cell types available , even advises you on different make & types, See if you can get old Battery out of Buddy Range Finder,
Mar 14, 2015 | GolfBuddy Golf Buddy - dsc-gb200 - Golf...
Part missing
I have your range finder and I am missing the battery cover so it will not work without
Dec 26, 2013 | ION Audio ION blk Rangefinder
Code P0342 - Chevy Aveo Sedan 2006. Last 2 months, when starts the car engine getting
Hello! The trouble code is telling us that the voltage to the Camshaft Positioning Sensor (CMP) is low...The connector that plugs into the sensor could be open, the sensor itself defective or low battery input to the sensor...See diagrams below as to sensor location...Lets eliminate...The wire colors in the CMP plug are...Pink...Black/White...And Light Blue/Black...If you connect a voltmeter to the Pink wire you must read 5 volts...Push a safety pin into the rear of the in-place connector into the Pink wire so it contacts the pin that the wire is crimped to...(+) probe of meter clipped to that pin and (-) probe to bare metal chassis ground...Key on...Meter set to read 5 volts...If 5 volts is present that eliminates a battery fault...Next push the safety pin into the Light Blue/Black wire...Turn on key...(+) probe to that pin...Should read about 2.4 volts...If you read nothing, or less than 1 volt the sensor is defective OR the connector pins to it are fouled...Pull plug and inspect both male/female pins for oil...corrosion...etc...Radio Shack sells a product called DeOxit...It's the best (no touch) spray contact cleaner...Send results...PS...Best meter to use is a digital one...$20...Guru...saailer
Remove engine cover:
CMP at top of drawing with timing chain cover removed for clarity...
Feb 25, 2012 | 2006 Chevrolet Aveo
Cant take cover of wont slide off
To remove the side cover: There's a small pin in the back which you'll have to press it down and slide the cover at the same time. (It's has a L shape plastic covering the pin.. Sometimes if the plastic cover is lost just press tha pin down)
Good Luck
Oct 10, 2011 | Dell Dimension 2400 PC Desktop
Replace cylinder without the old key (lost). I have depressed the retaining pin ok, but the cylinder seems 'sticy' and won't pull out. How hard is it supposed to be to pull the old cylinder out...
The problem you are experiencing is because the retainint pin will not push in unless the ignition switch is turned to the "ON" position. This cannot happen if you do not have the key.
If the key is lost or the cylinder will not turn for any other reason, then the retaining pin must be DRILLED out using a 1/8" drill bit. (see picture)
NOTE: When drilling out the retaining pin, take care not to damage the cover cast housing or the hazard flasher switch.
Aug 13, 2011 | 1991 Ford F150
Pasword lost
If this is a BIOS password you are referring to, clearing CMOS might remove it. There will be a jumper near the battery covering two of three pins, move the jumper to cover the middle pin and the uncovered pin. Wait a few minutes, then move it back.
Jul 22, 2011 | Computers & Internet
Hi!
Nov 15, 2007 | Nikon Laser 800 Rangefinder
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
