Question about Pioneer KEH-P2800 Cassette Player
Wiring Lost my wiring connector that plugs into the back of the deck. There are twelve metal posts in a row, starting left to right (b.reny-acc-fr-fr-fl-fl-b.up-rl-rl-rr-rr) the speaker connection are no problem, its the positive and negative connection I'm not sure of?
    Novelist:
    Champion:
  • 218 Answers
I would think that the "b.up" connection would be the backup connection that stays "hot" always. However, I have no idea what "b.reny" would be and I think techman is right about the "acc" connection.
Posted on Jun 10, 2007
    President:
  • 3,130 Answers
The B.reny connects up to an ALWAYS on power source in your car, like right to the battery or a terminal in your fuse panel that is always on even if the key is off, and the acc hooks up to a swiched power sourch, like where the original radio was connected, as the acc is called the memory wire. good Luck
Posted on Jun 09, 2007
How to connect EPIA_M860-12E to a monitor for starting it?
1) Power Supply to Motherboard
2) Motherboard to Monitor
Motherboard has Processor, and Ram Memory on it.
Monitor cable plugs into I/O area on motherboard.
(Input/Output area. Where the Mouse/Keyboard/Audio ports, etc, are)
You can lay the motherboard on a piece of cardboard, then on the table you're working on.
Make SURE you are FOLLOWING Anti-Static Precautions. If you are not aware of what these precautions are, please post back in Comment.
To start the Power Supply, jump the two contact pins in the Front Panel header on the motherboard, with a small flat tipped screwdriver. (Jewelers screwdriver is the best for this)
(The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Main wires being;
Power On switch, Power On LED light, HarDDrive activity LED light, and Restart switch; IF your computer uses a Restart switch )
http://ep.yimg.com/ca/I/yhst-27518546784426_2237_361300875
http://www.tragant.de/pdf/32992-4f05de2de5d79.pdf
If that doesn't start the Power Supply, then use a jumper wire on the Green, Soft Power On wire, to ANY Black wire. ALL Black wires are Ground wires. (Negative connection)
The contact period is NO more than 2 seconds.
http://www.viaembedded.com/en/products/boards/1510/1/EPIA-M860.html
Bottom -> Users Manual UM_EPIA-M860_113.pdf
After you click on the above, a small window will come up on the right.
Make SURE there is a Green dot in the small circle to the left of -
Open with.
If not, click in the empty circle to the left of Open with.
[Should state Adobe Reader (default) in the box to right of Open with]
The Front Panel header is on Page 31 (Adobe Reader page number box at Top)
Two rows of contact pins.
TOP row is numbered EVEN.
BOTTOM row is numbered ODD.
Top row from Left to Right, is Pins 2, 4, 6, 8, 10, 12, 14, and 16.
Bottom row from Left to Right; is Pins 1, 3, 5, 7, 9, 11, 13, and 15.
Pins 6 and 8 are for the Power On switch.
{ Pins 2 and 4 are for the HarDDrive activity LED light.
Pins 10 and 12 are for a Reset switch, IF a Reset switch is used.
Pins 14 and 16 are N/C. Not Connected.
Pins 1 and 3 are for a Dual color Power On LED light.
Pin 5 is the Ground for the Dual Color Power On LED light.
Use pins 5 and 7 for a two wire Single color Power On LED light.
Pins 9 and 11 are N/C.
Pins 13 and 15 are for an internal speaker. The small speaker/buzzer for hearing BIOS Beep Codes ]
The main power cable is a 20-pin ATX main power cable.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
You want the main power cable plugged into the motherboard, as shown in the photo to the Right.
The Green wire is the Soft Power On wire.
-> ANY Black wire is a Ground wire.
The preferred jumper wire is a straightened out paperclip, bent into a U-shape.
The top of the U is wrapped a few times with black plastic electrical tape. This taped area is for your fingers, and thumb to hold onto.
Turn the U shape over, and it is the 'legs' of the U that you are going to use.
One leg goes down into the socket hole, where the wires go into thew connector; RIGHT NEXT TO the Green wire, and slides down in.
Slides past the green insulation of the wire, and Touches a metal terminal at the End of the wire. MUST touch that metal terminal.
The other leg goes down into a socket hole, with ANY Black wire in it.
The contact period is no more than 2 seconds.
Power Supply comes on you have a bad Power On switch.
Power Supply does NOT come on; you have a bad Power Supply.
The Soft Power On circuit is 5 Volts DC.
In comparison two D cell flashlight batteries produce 3 Volts DC.
However, not stating that there may be a small spark, as you connect the U-shaped jumper wire.
For this reason you may wish to use a glove, on the jumper wire hand.
Cross-compile connections? I am at a loss.
Explain further in a Comment.
Regards,
joecoolvette
Nov 30, 2012 | VIA Epia M860-12e Fanless Mini-itx...
What's your problem? I need a schematic for my HP Pavilion slimline
http://h10025.www1.hp.com/ewfrf/wc/product?product=3688725&lc=en&cc=us&dlc=en&lang=en&cc=us
Ready for a long read?
A) Power Supply /Motherboard
Motherboard with no hardware components installed, nor cables attached,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321559&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3688725
I also would like you to scroll down a little further, and click on the + sign to the left of - Motherboard layout.
Shows an illustration of the motherboard.
1) 24-pin ATX main power cable:
Looking at the motherboard illustration (Motherboard layout), look at the Top/Middle.
ATXPWR1 is where the 24-pin ATX main power cable plugs in.
In the photo you see - ATXPOWER and CPU_FAN above this black connector.
[ Processor fan {CPU Fan}, is the first white 4-pin connector, to the right of the black 24-pin ATX main power cable connector.
A Chassis, {Computer case} fan plugs into the next 3-pin brown header to the right.
That was the only space the motherboard manufacturer had, to mark the motherboard for those two connectors ]
This shows a general example of this type of power cable.
(Note color does NOT matter),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the Lock on the side (Middle) of this power cable's connector.
Also note the matching Tab on the motherboard connector.
The Lock operates like a see-saw on a playground. The top is squeezed in to bring the hooked end of the Lock, away from the Tab on the motherboard connector.
When this power cable is deemed to be plugged in properly, and tightly, the Lock's hooked end will be over the Tab.
That concludes the power cables coming from the Power Supply, to the motherboard.
B) Power Supply / Peripherals:
The Harddrive is a SATA unit. 500GigaByte, and has a 7200 RPM spindle speed.
There is a SATA power cable that plugs into it.
General example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note that a SATA power cable has 15 contact pins. It is the longer of the connectors when comparing to a SATA data cable connector.
(7 pins)
The optical drive (CD/DVD burner that has LightScribe technology), is a SATA unit also. Uses a SATA power cable.
A) Data Cables:
The Harddrive, and optical drive require a SATA data cable.
General example of a SATA data cable, and SATA data connector on the motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the SATA connector on the SATA data cable.
Has an L-shape on the inside. Lines up with the L shape on the motherboard connector, and Harddrive and optical drive connector.
The red connector shown is a SATA data cable connector, on the motherboard.
Looking back at the HP Support page, look at the illustration.
The Ram Memory slots are designated by XMM1 and XMM2.
To the bottom left of them are the two SATA data connectors.
SATA 1 and SATA 2.
In the motherboard photo you can see they are plainly marked.
SATA 1 is White, SATA 2 is Black.
The Harddrive plugs into SATA 1.
An optical drive will plug into SATA 2.
Most of the time a SATA data cable will have a 90 degree bent elbow, for plugging into the Harddrive, and Optical Drive.
The straight connector end plugs into the motherboard.
A) Processor Fan and Chassis Fan:
I have already stated where the processor fan plugs in, and the Chassis (Computer case) fan plugs in.
A) USB Front Panel:
The Front Panel is the front of your computer. The USB headers on the motherboard, USB1 and USB4, are where the front USB ports plug into.
These headers (Connectors) are to the right of the SATA data connectors. (F_USB1 and F_USB4)
A) Front Audio:
The long Black slot at the bottom of the motherboard, is a PCI-Express x16 slot. Used for a graphics card.
To the left of it is the Front Panel audio connector.
F_AUDIO1, and is Yellow in color.
A) Front Panel header:
As stated the front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires go to, is the Front panel header.
On the motherboard illustration it is at the Bottom/Right, and marked as F_PANEL1
Horizontal header, and two rows of contact pins.
4 on the Top row, and 5 on the Bottom row.
IF, I have this pinout correct;
Pins on the Top row are number EVEN.
Pins on the bottom row are numbered ODD.
Starting on the LEFT side coming towards the Right, Top row;
Pins 2, 4, 6, and 8. There is No Pin 10.
Starting on the LEFT side coming towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. (It's a 5 Volt power wire used for factory testing )
D) Pins 2 and 4 are for a Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is No Pin 10.
Hopefully you just have a cable with a connector on the end, that plugs into the Front Panel header.
Same with your Front Panel USB ports, and Front Panel audio ports.
After you have hooked up all cables, and deem to be finished, take the Ram Memory module/s ('Stick') out, and reinstall.
Most of the time they get bumped loose, and you CANNOT see by a visual inspection if they are.
Best method is to just remove them/it, and reinstall. This way you are ASSURED they are seated, and tight.
I Hope you have been FOLLOWING Anti-Static Precautions.
If not plan on using your motherboard, Processor, Ram Memory, Graphics card(?), and harddrive, for an expensive paperweight.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Relieve your body of Static electricity BEFORE reaching inside your unplugged from power computer, or removing any new parts out of their anti-static bags, or cartons.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal framework of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
For additional questions please post in a Comment.
Regards,
joecoolvette
(You do have that computer laying on it's side, right? Much easier to work on. I use a static free, clean towel on the table, to protect the table, and the computer case )
Oct 04, 2012 | HP Pavilion Computers & Internet
Component input won't work
There are 2 rows of RCA connectors on the back of this TV.
If you are looking at the back of the TV, on the right side you'll find the connectors.
On the bottom row, left most RCA jack is the Video in for the Component video.
on the top row, the right 2 connectors are for Audio connections.
we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
Sep 24, 2012 | Emerson LC391EM3 39 in. LCD HDTV
Need diagram for connection on motherboard 4006272r
Gateway 4006272R motherboard;
Foxconn (Bengal) RS780 motherboard.
[ In otherwords the motherboard chipset is an AMD RS780 series,
http://en.wikipedia.org/wiki/AMD_700_chipset_series#780G.2F780V
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Radeon_R600_series
Scroll down to the bold black subheading - IGP (HD 3xxx, HD 4xxx ]
This motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
In the list click on -> Product Views
Now click on -> S - Front Panel Connector
Motherboard installed in the computer case, the Front panel header is at the Bottom/Right corner.
It has -> F_PANEL <- silkscreened in white underneath it.
Two rows of pins.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side, coming across to the Right;
Top row;
Pins 2, 4, 6, 8, No pin, 12, and 14.
Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
Pins 11, 12, 13, and 14 are NOT USED.
If the HDD LED is dim when the harddrive is active, switch the wires around.
These pins are in the Orange blocks.
These pins are in the Blue blocks.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
Black block.
D) Pins 2 and 4 are for the Power On LED. (Light)
If the PWR ON LED is dim when the computer is on, switch the wires around.
These pins are in the Green block.
These pins are in the Red block.
F) There is NO Pin 10.
Black block.
Again, Pins 11, 12, 13, and 14 are Not Used.
B- CPU Power Connector is at the upper left corner of the motherboard. This power cable is power for the Processor.
MUST be plugged in.
A general example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Note the Lock on the side of the power cable's connector, and matching Lock Tab on the motherboard connector.
F- Main Power Connector also has a Lock, and Lock Tab.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
D - CPU Fan Connector is above the processor socket, and near the top outside edge of the motherboard. ONLY plugs in one way.
Regards,
joecoolvette
Aug 10, 2012 | Gateway Computers & Internet
I'm having trouble with the pin out connections on a syntax motherboard. Where can i find a diagram?
Align the motherboard in your mind, so that we are both looking at it in the same direction;
Processor to the top, Ram Memory slots to the right, the four white PCI slots to the bottom.
The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel go to, is the Front Panel header.
The Front Panel header for the Syntax SVM266A is below the IDE 2 connector. It is labeled Panel 2
(Harddrive plugs into the IDE 1 connector, optical drive/s plug into the IDE 2 connector)
Panel 2 is mounted horizontally. It is parallel to the IDE 2 connector.
There are 4 pins across the Top row, and 5 pins across the Bottom row.
The pins are numbered. Even across the Top, Odd across the Bottom.
1) Starting from the Left side going towards the Right, for the Top row;
Pins 2, 4, 6, and 8. There is no Pin 10, just a blank spot.
2) Starting from the Left side going towards the Right, for the Bottom row;
A) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
If the Power On LED light is dim, switch the wires around.
B) Pins 6 and 8 are for the Power On switch.
C) There is no Pin 10
D) Pins 1 and 3 are for the Harddrive activity LED light. (HDD LED)
Pin 1 is for the positive wire.
If the HDD LED light is dim when operating, switch the wires around.
E) Pins 5 and 7 are for a Reset switch, IF a reset switch is used.
As for a motherboard manual,
http://web.archive.org/web/20060206024804/http://www.syntaxgroups.com/support/downloads.php
Scroll the page down to about 3/4ths the way down, until you come to the bold heading -
SVM266A
Click on Manual.
This is a PDF file. It may take up to 30 seconds before the first page comes up, and additional time for the file to fully download.
Regards,
joecoolvette
Oct 16, 2011 | Syntax SVM266A (SYSVM266A) Motherboard
No sound from left speaker on right deck. left deck is fine. confused! tried unplugging one at a time and only the right plug is working. is there anything simple i can do to rectify this problem? as...
To find out what the problem is try this, swap over the right and left leads from the deck to the amp. If the problem stays on the left channel there's something wrong with pre-amp in your amp. If it goes to the other channel (right dead) it's the deck. Next remove the wires to the cartridge to the deck with the fault. Make a note of how they fit on the cartridge before you do. With the amp connected to the deck and on. Touch (one at a time) each of the four wires with your finger. Two of them will probably produce no sound. But from one wire you should hear a buzz on the left channel and from another wire a buzz on the Right channel. If you get a Buzz on the left speaker then all the connects are good and the cartridge has gone. If you don't get a buzz, then there is something wrong with the left cable connector between the deck and amp.
Jun 01, 2011 | Technics SL-1210 Turntable
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
Runs in park, put in gear drives a bit, then stalls
If you have a twelve pin connector for test, (just to the right of the column under the dash)you can jump from the second terminal (going right to left) on the top row, and ground. ck eng light will flash codes.
Personally from what you have said, i'd lean towards either coil, fuel pump.or filter. See if you can pull codes...
Apr 04, 2009 | 1989 Buick Regal
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Asus P4GE-MX
If you have your manual you can see how to connect these on pg. 1-22. No manual..
Starting from the right edge of the board moving to your left. Notice there is two rows of pins one above the other. All your case connectors will be connected left to right & not up to down. The first two (BOTTOM ROW) pins are for the reset switch. The connector will have two wires one will be colored white or black. These colored wires are ground & will be the sane for all your connectors. All grounds will face towards the right for both rows of motherboard pins. After plugging in the reset connector SKIP one pin as you move to your left along the bottom row. Plug in your IDE LED connector a two wire connector. Moving to the top row across from the ide led, plug in the Power Led. It is a two wire connector. Some case connectors for the power led come in a three pin connector. If yours is like that than you will need to remove the + wire from the connector & slide it over one slot so it is next to the ground & plug it onto the board.
The last two pins is for the Power button. All Asus boards are marked & colored. You need a stronge flash light to see the markings on the board. Good luck!
Don't forget to vote..........
Jan 15, 2008 | ASUS P4GE-MX Motherboard
Pioneer KEH-P2800 Cassette Player Logo
224 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
