My packard bell istart 8207 will not start all fans are spinning and showing red light not blue
And it will not switch of. the fans speed up.
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit. If you can get your computer stable enough scroll to bottom toolbar bottom of screen right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs not having enough computer ram can cause memory dumps If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible. You might have a virus or malware. Download at least one of these of course it will depend on your operating system. http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Hope this helps.
Posted on Dec 08, 2012
SOURCE: Suitable psu for packard bell istart 1359
Dera Telxon,
The PSU you have linked is FSP250-50LPU - which is not the one in question.
Thanks and regards,
Bandi
Posted on Mar 02, 2008
greg_margo
  • 1959 Answers
SOURCE: hi when i start up my packard bell imedia i get a
Assuming the monitor is fine you can try the following:
  1. Open the machine and reseat the video card; if video card is onboard try
  2. Unplug the machine and remove the CMOS battery for a few minutes; Its possible Windows didn't shut down properly and CMOS is preventing a normal startup; after replacing the battery, boot up (will probably start up in safe mode
If neither of these fixes the problem, you may have an issue with the monitor itself. Best of luck.
Greg
Posted on Jun 11, 2009
SOURCE: wireless button on packard bell easynote MV35-202?
Fn / F1 or some models are Fn / F2
Posted on Oct 06, 2009
  • 468 Answers
SOURCE: i have a packard bell istart 1359 i just wondered
Here you have link for driver downloads
http://support.packardbell.com/uk/item/index.php?pn=PB49300701&g=2000
Posted on Oct 13, 2009
  • 97 Answers
SOURCE: HI THERE MY PACKARD BELL 2215 IMEDIA WILL NOT BOOT
Sounds like an overheating problem. Clean the dust out of it, make sure it can get air on all sides, make sure the fans are turning. If that doesn't work, unplug the computer, hit the power button 20 times, wait 1/2 hour and boot it up.
Posted on Apr 22, 2010
Packard bell. when switched on the power light starts flashing blue and the fan kicks in i haven't had in on for about 4 weeks ... anybody ??
you are getting a post error from a hardware componet... if your system ismore than 5 years old its time to say good bye andreplace..
Aug 17, 2013 | Packard Bell Computers & Internet
Packard Bell istart 1369 switchung off when warm
I assume you have had it for a while? May be the CPU, Graphics, Mobo/components, memory, etc.? Have you adjusted the Power Options in Control Panel, High Performance, Sleep and Hibernate to Never? Things start going one by one. Short story, I had a HP/Compaq SR1120sx, first the PSU, then the Audio, one channel, etc., etc., etc. If I continued replacing components the cost would have bought a new one. With the cost of Desktops and Laptops, due to the rise in Tablet, netbook, Smartphones, it may be wiser to buy a new one. Take a look at the Desktop prices and you make the decision. Invest in the old one or.......Perhaps it's time to let her go? A kiss on the cheek and send her out into the world.
May 08, 2013 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I need help please i am looking for sound card driver HP PACKARD BELL iSTART C2389. I am running Win XP SP3.
here you go: http://www.driversforfree.com/omn_ofm_omd_dd/packard-bell/istart/c2389/packard-bell-realtek-hd-audio-driver/search.aspx
hope it works..
Feb 22, 2011 | HP Computers & Internet
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
I have a packard bell imedia 5050 desktop when switched on only shows a orange light and will not power up from there can you help ?
Sounds like a power supply. the power supply in the tower may have overheated or burned. Does the fan in the power supply come one?
Jul 11, 2008 | Packard Bell Computers & Internet
Unfortunately, no. See this link for a picture of your supply: http://www.cwc-group.com/fspgrfsposu2.html . It's considerably longer and narrower than a standard ATC power supply. This is typical of Packard Bell, e-Machines and many others.
Hope this helps!
Jan 31, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
