Question about Mitsubishi WD-65738 DLP TV
I have a mitsubishi wd 65738 and peoples faces appear smudged on the cheeks. Almost like a 5 o clock shadow. I have seen this before on other DLP tvs as well. Is this a light engine or main board?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I have in the shop also seen this issue on a few Mitsubishi sets, you may want to search for the service manual but I worked for a authorized service center for this brand and they had all kinds of issues--one was when the Optical engine was replaced there was a procedure done with the remote to mate it to the main chassis (set had reddish smearing--not extreme but noticeable. the procedure cured that.
These sets had so many digital issues with dozens of surface mounted caps on several boards failing that a few years ago they offered an entire signal chassis on an exchange basis.
The engine as you may (from the tone of your question) be aware is in constant communication with the main signal chassis---not very helpful I admit but it could be either----if that chassis is still available it wholesaled for about 250 and the engine might be more than 500---they are nice guys as the engine does not come with some mounting brackets etc that have to be removed from old one.
Good luck and see if you can find (I have seen some on the internet) a free download of that which may or may not help.
Posted on Dec 04, 2012
  • Patrick McAlexander Jan 30, 2013
    I thought I would post the solution to this problem. After changing the optical engine three times and the power supply and main board once each, a tech at mitsubishi suggested the ballast. VOILA! Perfect picture! Apparently Mitsubishi is having issues with wrong firmware on these ballasts.
techman
  • 3130 Answers
SOURCE: Mitsubishi WD 73727 73in
Contact Mitsubishi with the proof of this and demand a new TV set. Maybe it is the service shop causing this, your warranty should also be extended for the time you were out of the use of the TV set while waiting for parts. If this does not work, the state attorneys office should be able to get you a new set or at least this one repaired. Good Luck
Posted on Sep 27, 2007
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
SOURCE: bugs are inside tv seen on inside of screen, how
How do I remove the screen to remove bugs?
Posted on May 25, 2010
I have wd 65738 Mitsubishi tv that has a problem can you help ME?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 17, 2016 | Mitsubishi WD-65738 DLP TV
I have replaced my bulb several times on my mitzu wd65738 dlp but this time is different....will not boot green light flashing constantly 2010 model
its bad capacitors in the power supply. Pretty common. The power board is available on eBay from what I have seen
Aug 29, 2015 | Mitsubishi WD-65738 DLP TV
How to split a 60" mitsubishi medallion series into half...to carry it easier.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Sep 04, 2014 | Mitsubishi WD-65738 Medallion 65 3D DLP...
Mitsubishi 65 dlp
SOUND LIKE A BAD COLOR WHEEL...HEAR A LINK TO SEE IF THAT THE SOUND YOU ARE HEARING ....http://www.youtube.com/watch?v=hUiYRqrNxxU
Dec 24, 2013 | Televison & Video
65738 colors flickering after bulb replacement
check the colour wheel in the light engine most likely bearings are worn needs replacement and the colors will stabilize need to open the light engine and replace with a new one
Mar 08, 2013 | Mitsubishi WD-65738 DLP TV
Mitsubihi WD-65738 no power, no lights. Is there a fuse I can check? Maybe by the plug?
Follow the power cord inside to the power board--line fuse will be there--have fun and patience as a lot of screws to remove to get there---as seen from rear power board should be to far left side.
Dec 03, 2012 | Mitsubishi WD-65738 DLP TV
5738 status light blinks red 5 times then orange 7 times
if it is a 7 then u must replace.
SOURCE: i am a mechanic
Jan 21, 2012 | Mitsubishi WD-65738 DLP TV
I have a mitsubishi wd 65738. My picture suddenly went dim. I can still see a picture but the room has to be very dark and its still hard to see. Do I just need to replace a bulb?
Hello
Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
May 27, 2011 | Mitsubishi WD-65738 DLP TV
Mitsubishi WD-65738 DLP TV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
