Question about Hoover S2220 Flair Bagless Upright Vacuum
Carpet setting not working
There's two settings to my vacuum cleaner (hoover S2220 flair bagless) but only the 'floor' setting seems to be working, and i can't get the carpet setting to work. the vacuum did smell of smoke, so i took it apart and cleaned the nozzle, belt, etc (i think the smell came from hair and other things stuck on the brush because i wasn't even able to manually rotate the brush). however, even after i cleaned out the debris, carpet setting was still not working. is the brush supposed to rotate while the vacuum is on? because it definitely wasn't rotating on its own when i turned it on...and the vacuum suction power is definitely not as good as it was before....
thank you!
  • 294 Answers
There is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Posted on Jan 17, 2009
How do I change the belt?
To change the belt on a Hoover Flair Stick Vacuum, remove all 6 screws from the bottom of the beater bar. There are 2 screws hidden under wheels. You must pop the wheels off with a screw driver to remove the hidden screws. The cogged belt is on the left side of the beater bar. Be careful not to pull the wires.
Jan 22, 2013 | Hoover S2220 Flair Bagless Upright Vacuum
Attachment of vacuum base to handle
yes friction and the air suction presure keep the head and the handle together.
Jul 25, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
How does the cloth bag attach in the ''Flair bagless Hoover'' ?
take the dirt canister out and it just drops into that and sits flush. then reinstall the canister
Jan 03, 2010 | Hoover S2220 Flair Bagless Upright Vacuum
Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Oct 25, 2009 | Hoover Vacuums
Flair motor shorting out?
There's a thermal cut-off when the unit has overheated. Mine does this quite often and I remedy it by emptying the canister and making sure the filter is clean, especially of lint and things that prevent good air flow.
Jul 07, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover Flair S2200
Should be the same, Hoover would only have one S2200 model and it doesn't matter who is selling it.
Nov 26, 2007 | Vacuums
Hoover S2220 Flair Bagless Upright Vacuum Logo
664 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
