Question about Zoom H1 Handy Ultra Portable 24-bit Stereo Digital Voice Recorder
Zoom h1 recorder
Will not turn on
Zoom h1 handy recorder
Have you tested the Micro SD card? Check it with your computer and load an MP3 to it. Play the recording in the Zoom to check the Zoom
May 27, 2014 | Music
Have you tried updating your Zoom's Firmware to the latest version? That may just clear and reset the device to normal operation.
Oct 06, 2017 | Music
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
H4n zoom wont record says card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 23, 2013 | Samson Technology Zoom H1 Recording Bundle...
My new Zoom H1 will not connect to computer through USB.
Hi did you get it sorted,got the same problem,dont want to have to send it back only got it today, saving for ages,can you help
Oct 28, 2012 | Samson Technology Zoom H1 Recording Bundle...
H1 wont power on
I just discovered the same problem with my H1. When plugged to computer, nothing happens neither. It turns out it may be just the contact issue. You will have to carefully disassemble it (you'll need one small screw driver. watch for the small wires). There are two PCB boards one on top of the other, and between them there is the contact that I believe came loose or dirty causing the issue. Play with that, and with battery in, try to turn it on.
Apr 03, 2012 | Samson Technology Zoom H1 Handy Recorder
Zoom H1 says
What format are you recording in? Recording in the standard resolution WAV format will only give you about 3 hours in total on the 2GB SD card that comes with the H1, whereas lower resolution WAV recording or MP3 recording will give you more hours, more than 34 hours form MP3 at 128kbps.
Mar 03, 2012 | Zoom Audio Players & Recorders
I just bought a Zoom H1 and the SD card won't format. What should I do?
OK... first thing is to make sure the SD card is 2 Gb or less as larger won't work.
Many of the SD card has a protect switch that prevents writing to the card... it is a real tiny littl thing to move with your fingernail. You might need a magnifier to see it.
Apr 01, 2011 | Samson Technology Zoom H1 Recording Bundle...
Zoom H1 Handy Ultra Portable 24-bit Stereo Digital Voice Recorder Logo
63 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
