How do you change the belt on a bang and olufsen beogram Rx2 Turntable? I can't see how to get at the drive spindle.
57 varieties
  • 1653 Answers
SOURCE: Bang and Olufsen Turntable will not platter will not spin
Normally on the RX-2 there are only 3 transit screws but if they are stuck you might need to gently try to lift them while turning anti clockwise. You can do this with a Steel Ruler and yoiu may have to use a little bit of force as some people torque them down tight. As for manuals and service manuals - they are rare!
Posted on Oct 07, 2009
mighty thor
  • 51 Answers
SOURCE: Beogram 1800 wont play the record!!
possibly some kind of obstruction inside.
I had something similar with my turntable, and it had a dirt dauber nest inside it!
no kidding.
Posted on Dec 05, 2008
djproaudio
  • 515 Answers
SOURCE: Ion ittusb turntable drive belt
If the belt is stuck, it will be hard to take off without damaging the belt. Send it back.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
  • 122 Answers
SOURCE: belt drive replacement B&O Beogram 1000, type 5203 turntable
length approx 30mm shorter than old one, knock out pin on shaft to take platter off.more often than not the motor runs slow after repair,if its a round style ac motor htey cant be fixed.
Posted on Jan 11, 2010
  • 122 Answers
knock pin out.make sure idler assy moves freely away from motor shaft.
My bang and olufsen 7002 wont select the phono stage
The Phono/Aux input has a slider switch to the left of it to choose whether to make it a regular line-in jack or to utilize the phono stage. The ground terminal is just above the jacks. The Beogram 4002 likely has a muting circuit that's in effect when the tonearm is in the lift position, which would explain the lack of hum til the stylus lowered to the record.
May 19, 2015 | Bang and Olufsen Audio Players & Recorders
I have a Bang&Olufsen Beogram
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Jul 08, 2008 | Audio Players & Recorders
How do I change Bang & Olufsen Beosound 2000 door belt?
I just did that ; took an 031 oring or was it an 032; and you have to pull the whole drive mech out; it is tricky and if your not small mech inclined don\'t do it; There is a few gears and they work in tandem so when you put it back together it has to be just right; if you take it out take pictures of it as you take it apart because you will never remember how it goes back together; easy to get out; a pain to put back together. And it will all come apart just to put that oring in.
May 31, 2013 | Bang and Olufsen Beosound 2000 Shelf...
Can't operate the turntable and tapes. Radio OK This is a Beosound 2000
its likely you have 2 seperate faults.parts for the tape deck are discontinued.check belt on turntable, if its ok not much else can be done,no spares!
Jan 04, 2010 | Bang and Olufsen Beosound 2000 Shelf...
I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
Dec 24, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Oct 07, 2009 | Audio Players & Recorders
B&O Beogram 2000 turntable arm won't go down
Check to see if there is a cueing lever that is holding the arm in the up position.  If no cueing lever and it has worked recently then something has happened to the changer mechanism.  Open the bottom and look to see if there is an obvious problem like something stuck or broken.  You may be able to make the mechanism go through its cycle slowly by rotating the platter with your  hand so you can see where it is getting stuck.
May 30, 2009 | Bang and Olufsen Beosound 2000 Shelf...
no kidding.
Dec 03, 2008 | Audio Players & Recorders
628 people viewed this question
 Grubhead
Grubhead
