Question about Microsoft Wireless Notebook Optical Mouse VSBX300008
Where's the battery????
I'm checking for the battery in the 1024 Microsoft Notebook receiver wireless mouse.
help please
  • tomvette630 Jan 12, 2009
    Found it . . . .duh
    Novelist:
  • 194 Answers
If you consider the button and wheel side to be the front -
There is a silver oval button at the back of the mouse. Press it and the top of the mouse just behind the mouse buttons will pop open.
It takes 1 AA battery with the negative side going to the front.
Posted on Jan 12, 2009
  • 827 Answers
Turn the mouse upside down. Remove the battery compartment cover. It takes 2 AA batteries.
User Manual:
http://www.amazon.com/Microsoft-Wireless-Optical-Mouse-Blue/dp/B000068MP5
Hope this helps
Chris (ziraffa)
  • 81 Answers
You should have a silver button that is a logo on top of the mouse under where your palm sits. Push it. Should pop open secret battery compartment. Hope that helped!
Microsoft notebook receiver model 1024
issue? Check the battery, try syncing it using the connect button on the mouse, make sure the receiver is plugged into a working USB port.
Jan 03, 2012 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
Do you have another device to test the batteries in to be sure they are good? Also verify the batteries are inserted properly - if so, it appears the mouse has just quit working.
Dec 29, 2008 | Microsoft Wireless Notebook Optical Mouse...
I want to download a wireless mouse No. 1024
If you want to download a driver for a Microsoft wireless notebook mouse, go to one of the following locations:
http://www.mediafire.com/?sharekey=9144041283e5344bd2db6fb9a8902bda
http://www.microsoft.com/downloads/details.aspx?familyid=EA22BD62-4873-406A-BBBE-C587D35A53BF&displaylang=en
After you download the driver, run it and select which mouse you have.
Nov 18, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook optical mouse 1024`
I have a Microsoft wireless optical mouse 3000. There is a silver button on the end of the mouse that usually faces you when using the mouse. Press that silver button- while holding the button in, use your fingernail or something to help with gently lifting the main panel on the top part of the mouse. Lift up on the end of the panel that is closest to the silver button. The panel comes entirely off, revealing the inset battery. It took me a while to figure it out since I installed the first battery.. it has lasted over a year. Hope this helps with yours. Have a blessed day!
Jul 12, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Mouse Wireless Model 1023/1024 won't work
try using an eraser on the contacts if you can reach them. Sounds like dirt/corrosion build-up.
Jun 15, 2008 | Microsoft Wireless Notebook Optical Mouse...
My green light on the receiver is ON. The mouse battery is new. The red LASER switches with movement. I read all of the posts, than I pulled apart the receiver and the wires were OK. There is a micro-switch in the receiver, so I pushed it when plugged in to the computer. The green light flashes, then I pushed the button on the bottom of the mouse, it connects. To make short of this, do not open the receiver case, just use a pen and push the green "connect" light (must be in USB port), it will activate reset switch and blink. Next, push "connect" on the bottom of mouse.
Nov 27, 2007 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse VSBX300008 Logo
280 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
