Question about Avocent SwitchView® 1000 8-port KVM Switch
Kvm switch keyboard and mouse not working
When I plug in a new computer I see its display but the keyboard and mouse are not working
5 Suggested Answers
Zphinx
  • 60 Answers
SOURCE: Avocent DSR4030 KVM over IP
Make sure you use the correct IQ modules for that Model of Switch.
If the the IQ module is a PS2 module you migth want to reboot the server.
Posted on May 11, 2011
Zphinx
  • 60 Answers
SOURCE: just bought a 4 port KVM and hooked it up and the
is that a Mouse/keyboard combo ? If so, try with a standalone Mouse and a keyboard. If the Keyboard and Mouse need Special Drivers the solution might not work neither.
I hope that helped.
Posted on May 12, 2011
Zphinx
  • 60 Answers
SOURCE: i ve Avocent switchview osd.in
how did you connect from the switch to the server?
Did you reboot your server?
Posted on May 20, 2011
Zphinx
  • 60 Answers
SOURCE: Avocent KVM switch keeps turning
the switch should beep if you switch between channels or Ports.
It seems that you might want to download the manual and try to reset the unit. If this doesn't work call their support. Avocent has free support as far as I know.
Posted on Jun 16, 2011
I have a Avocent KVM I can swicth in between computers but the mouse and keyboard will work on one but not the other. I have reseated everything restarted multiple times to no effect.
Boot the computers in order making sure the one you are about to switch on is selected on the switch. Start with 1, then 2 etc. Make sure the computer fully loads and then log into it before moving on.
Oct 18, 2017 | Avocent Computers & Internet
How do I connect a usb mouse and keyboard to ps2 kvm switch?
usb to ps2 converter, the sell them for like 30$ but you can go to radioshack and buy a keyboard for that with the little adapter
Mar 30, 2013 | Belkin F1DL102P 2-port KVM Switch
Just hooked up the KVM cable and when I switch to the second computer, the mouse and keyboard do not work. Can someone help me with this?
Sounds like there's a bad connection on the second computer, may just have to plug another mouse/keyboard in.
(I sometimes use a wireless usb keyboard/mouse combo)
Jul 03, 2010 | IOGear GCS632U 2-port KVM Switch
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Sep 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Belkin 2-port kvm switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
My Keyboard only works on one PC but the monitor and mouse works on both?
Plug the key board and mouse directly into the computer that doesn't work, let it recognize the hardware and then reboot. After reboot, plug the keyboard and mouse back into the KVM and reboot again. That solved the problem for me. Most likely, the computer that doesn't work has never loaded the driver for that key board and does not recognize the input sent from the KVM.
Oct 09, 2007 | Belkin F1DK102U 2-port KVM Switch
Avocent SwitchView® 1000  8-port KVM Switch Logo
101 people viewed this question
Top Avocent Computers & Internet Experts
gary433
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
