I Have a Sony Vaio PC all in one Model No. PCG - 2J3L When you turn it on the screen will come on for 3 seconds and go black but you can hold a flash light to the screen and see it is still working or
Desk Top Computer
  • 7,627 Answers
A couple of thing will cause this, The backlighting is going out due to a tiny switch, that controls the light when you open and close the lid. It's located near the hinges, it can get stuck due to dust or a misaligned hinge. Take a look at this: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Posted on Dec 05, 2012
3 Suggested Answers
tgvern
  • 281 Answers
SOURCE: How do you replace the DVD/CD Player in the Sony Vaio PCG-2J3L?
It sounds like the bezel (the trim piece attached to the front of the drive) is what came off. You can usually still get it to open in this condition, but you have to get creative a bit.
typically the eject button is a physical button, but it depresses a small electronic button when you press it. This should get it to open. Otherwise, you can right-click the drive in my computer and select "eject". If that doesn't work, use the paper-clip method. Look for a small hole (on the bezel) which lines up with the emergency eject button on the drive. Straighten a paper clip and insert it at this point, which should eject the drive.
Then I would turn off the machine, (leaving the drive open) carefully turn it over. Look for a locking (retaining) screw on the underside of the laptop. On many models the screw is accessible without removing anything else, but I have seen where the screw is hidden under other components; proceed at your own risk here.
Once you have found the screw and removed it, that should be all that is holding it in. You can tug gently on the drive and it should slide right out.
From there, find the replacement model (I like ebay quite a bit for this type of part, since it will be much cheaper. Note the Model # which is usually on top of the drive on a label. It will make finding a replacement much easier than trying to shop by your laptop model #.
The key here is getting the correct type of data connection. As long as the bezel fits your computer, and unit will work (make sure you get the right kind of drive: DVD-R, DVD-ROM, CD-RW, CD-R, or some type of combo drive). While you can also find these parts on the internet, watch for some type of warranty on the product in case it fails to work. Many reputable sellers will have at least a 30 day warranty, which gives you time to test the product.
Once you have your replacement, examine it and make sure any trim pieces line up (you can also remove them from your old one if needed), then slide it into the slot, reinsert your locking screw, and you should be ready to test it.
I would test all functions of the unit right away: if it's a recorder, test burning a cd or dvd, play a dvd movie etc. to ensure everything works. I have seen a DVD-R drive that works for everything except recording DVD's (will play DVD's and CD's just fine, but not record).
Good luck and thanks for your question.
Vern
Posted on Dec 05, 2011
  • 12 Answers
SOURCE: sony vaio pcg-2j3l desktop will not power on
Just to clarify, the box (power brick) in the middle of the power cord is the power supply. With that said, there is a light on the box (may be green, blue, or some other color). Does it come on when you plug it in (assuming that the wall outlet or serge protector has power)? If it doesn't then the power cable needs to be replaced. If it does then there is something wrong with either the cable going between the box and the computer, the power connector, or the connector on the computer.
Posted on Oct 19, 2012
I have a Sony Vaio PCG-2J3L and when the lighting for the screen is on bright the screen will stay lite for a couple of seconds and then go black but you can take a flash light and turn it on the scre
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 04, 2012 | Computers & Internet
Sony vaio pcg-2j3l desktop will not power on
Oct 19, 2012 | Computers & Internet
I have a sony vaio model pcg-61611L. When I hit the power button it turns green and stays on but I cant get the screen to show a picture. I have taken the memory sticks out and tried them one by one but...
I have 3 of these laptop Pcg-61611l and all 3 are black screen on start up. Sony has a problem with this and is not saying any thing about it. What I do is turn on laptop let the green power bottom stay on ,walk away for 10 to 15 minutes then shut it down and restart you should see the three green lights by the power bottom flash twice and then your working again . Laptop will work fine until you turn it off. Repeat to power back up.
Mar 15, 2012 | Sony Computers & Internet
Sony vaio notebook pcg-3r6L im getting power but screen wont turn on at all
If the notebook appears to boot up and the hard disk LED is flashing and the LCD screen remains black, then the problem could be a faulty inverter or a faulty CCFL lamp.
To determine the exact nature of the fault and possible fix, please click on this link and follow my instructions :-
Jun 09, 2010 | Sony VAIO Notebook
My sony vaio model pcg-7y1l is not working. When
i had the same prob this morning there are 3 things you can try
1 memery
2 proccessor
3 hard drive
if not any of them
try the dvd drive
if not that then try exsternal monitor if dont show on that then motherboard is gone
Aug 14, 2009 | Sony VAIO VGN-AR230G Notebook
3 month old Sony Vaio notebook keeps turning off by itself, won't even last more then a couple seconds to a couple minutes, tried system restore and defragmenting, and disk cleaning...still nothing!! could...
Try on the BIOS/System Setup and check if its turning off there as well. To entere there, start your computer up, and when you see the Vaio logo press [Delete] several times. You will see a blue screen or black with information of your computer, leave it there for as long as it takes to shut down, if it doesn't then please let us know.
May 04, 2009 | Sony VAIO PCG-K35 Notebook
VAIO PCG-XG9 BLACK SCREEN
will i guest your computer have a major trouble...just try to check if the power led is ok the light is blink...or just check also if have 3 beeps sounds with regards to the video card...my suspect is weather a power supply of your computer or a video card is defective...let us bring that to the service center......
Dec 16, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
