Question about RCA RMW953 0.9cuft Microwave Oven w/ Display, Black
The icon with a line inside of a diamond shape within the display area..i can't use my microwave
All controls,lights,fans are normal. Turntable, microwave, convection do not work. Internal fuse?
There typically is an internal ceramic fuse. It is usually near where the power cord enters the oven, or behind the control panel (on over the range units).
The problem you are describing, though, sounds like it may be an open thermal protector on the cavity. Most are diamond shaped, with two wires. Unless the cavity is extremely hot, it should show continuity.
May 10, 2016 | Microwave Ovens
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Why panasonic microwave oven stops working
when it does that is power supply. they do that. change power supply and see what happens
Apr 29, 2014 | Panasonic Nn-sd681s 1 2cuft 1200 Watt...
Kot-170sb. No display or function at all. Outlet tested good. Is there a breaker in the unit that needs resetting or something like that?
The microwave oven has a main ceramic fuse located inside the unit under the keypad in towards the high voltage capacitor "silver and rectangular in shape" unplug microwave, remove top and allow 30 seconds for the capacitor to drain, use screwdriver and short across to make sure no charge is present, keep in mind the microwave carries dangerous high voltages.
Mar 07, 2011 | Kenmore 80412 Microwave Oven
Magnetron Ready to be Reinstalled but...
The sensor you detail has no polarity. It can go "either way"
For goodness sake be careful, I don't want to scare you but more servicemen, & would-be-servicemen die each year "trying" to service Microwave ovens. They are lethel, or rather the Main Capacitor is, it stores enough Joules to kill someone 10 times over.. Always ensure it is discharged to earth before working on anything.
Be careful.
Jan 21, 2010 | Microwave Ovens
Our microwave continually arcs when you start it up, so we quickly turn it off.
on the inside of the oven on the right you will find a small square of mica this is the wave guide cover have a look and see if it burnt or out of shape if it is then unplug the unit and remove and replace it make sure u clean the area where it sits as food can get behind the cover hope this helps
Oct 15, 2009 | Panasonic NN-H264 Microwave Oven
New Kenmore 63252
Hi , the oven are newly puchase so need to notify the kenmore appliance center to retain the warranty of the oven .
check the web site whatever recommendation by the kenmore.
Jan 02, 2008 | Kenmore 63252 Microwave Oven
RCA RMW953 0.9cuft Microwave Oven w/ Display, Black Logo
37 people viewed this question
Top RCA Microwave Ovens Experts
William Miller
William Miller
Mike Carew
Gerry Harvey
Gerry Harvey
Are you a RCA Microwave Oven Expert? Answer questions, earn points and help others
