Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
Seized engine oil ran low
    New Friend:
    Problem Solver:
  • 13 Answers
Could have to strip it and tap piston out but lubricate or could damage barrol
Posted on Dec 05, 2012
What parts on a 1998 eclipse gs break from running it out of oil
Often there are not any broken parts when an engine is ran low on oil.. The engine never really makes it to far out of oil before it welds the pistons to the side walls seizing the engine tight. Every now and then a rod will break because at hiway speed the engine went empty the piston seized but the crank and rod did not thus pulling it with such force to snap it in half then producing sometimes a hole in the engine block, hood, oil pan where ever it decides to go. And this is about it Crank not often cam not often. Hope this helps
May 17, 2015 | 1998 Mitsubishi Eclipse
CAR NOT STARTING IF NO OIL IN CAR WHEN STARTING CAN MOTER SEIZE IN HONDA ACCORD
Hi I'm Peter. I'm not quite sure if you are asking if a car will start with no oil in the engine or if the engine was ran with out oil until it seized up. Is this an engine that was just put in? If it was rebuilt and installed was running then froze up I would suspect that the person who rebuilt the engine made a mistake somewhere causing the engine failure. If you are asking that if you drained all the oil out of an engine would it still start and run the answer is yes. There will be a residual oil on all the metal components that would allow the engine to run for a while but eventually it would heat up from friction and seize. If you ran the engine low on oil possibly from it leaking out somewhere and the engine will no longer start then you just seized the engine and it will need rebuilt if possible or replaced.
Jan 02, 2015 | Honda Cars & Trucks
I have a 1998 Mercury Villager,its been smoking I got the oil channged thinking it was because my oil was low,its sti smoking and now.I have to jump start it ,if I want to drive it...do I need an...
If the smoke coming out (the back of the car exhaust) is dark grey...then you have a oil burning problem..this will cause your oil to be low sometimes quickly...if it is leaking out, sometimes oil leaks out on to exhaust under the hood, and can burn making smoke under the hood.. If the smoke is more white, then you have a head gasket problem. If you need to jump start your car, maybe you should drive to a national chain of auto parts store...they test batteries free...and test alternators free too...If you ran too low on oil, you might have a serious engine problem like a seized or nearly seized bearing, worn rings, or nearly seized motor.
Dec 08, 2014 | 1998 Mercury Villager
Ran low on oil car shut down added oil to right level car will not start. Took battery cable loose to rebot still willnot start
Seized !!! Engines are not computers, they will not "reboot"! You have heated two metals so hot that they have fused together inside the engine. Sorry you will need a new motor.
Oct 28, 2013 | 2005 Hyundai Elantra
Mechanic book
which engine? size?
the ECU nor any lamp can save the engine with no oil or too low
or never changed out.
you missed, week level checks.
and if levels drop fast (as it will driving real fast)
you check more often, in fact you learn what your engine needs.
my guess is loss of oil pressure,
the idiot lamp( just name) comes on with its TOO LATE..
on most cars made.
get a real gauge called oil pressure.
or the engine overheated
or just bad luck.
what seized, cam , crank or rod bearings.
the machinist will tell you for sure what failed.
the pump or low levels.
push rod engines. the rear rod bearings like to fail first (low oil)
then on overhead cams, they bite dust first. (top end oiling can fail easy)
also, on the last rebuild did (no 2 before) the PO, ran water for antifreeze this cause the internal freeze plugs to pop and
water in oil and rear rod spun(seized)
water makes really poor oil substitute.
when you take it down there are tons of clues.
blue metal.
oil looks like chocolate milk shack
bearings spun ,cam bearings gone.
cracks in block and head.
ever inch checked then pressure tested before rebuild.
Aug 08, 2013 | Jeep Grand Cherokee Cars & Trucks
Car shut off and was low on oil. I added oil but it still won't start.
If you ran your engine out of oil and it quit running before you could add more oil you just might have seized your engine. Always keep your engine filled to the proper capacity with oil.
Regards, Tony
Apr 15, 2011 | 2003 Nissan Altima
I have a 2005 mazda 6. it was 2 qts low on oil, i added oil, the car ran fine but had a slight rattle. 2 days later, i was sitting at a stoplight and the car died. my mechanic says the engine seized. no...
Hi . Unfortunately it's a common problem with mazda6 engine.When they run low on oil the crank shaft tend to get damaged.And some times people tend to top up oil rather than changing oil between 6000 &10000kms .Yep the engine is seized cost less replacing the engine than repairing it.good luck....
Jan 05, 2011 | 2005 Mazda 6
My oil light went on and than stop running. will not start. what could it be?
Sounds like you may have ran the engine out of oil or low on oil causing the oil pressure to drop and turning on your oil pressure light does the engine crank or rotate at all when trying to start it or does it just click? If the engine doesnt rotate theres a good chance you seized the engine up because of low oil pressure and you may be looking at another engine..... not good news.
Dec 08, 2010 | 2001 Suzuki Grand Vitara
How difficult is a low engine rebuild? I ran the bike low on oil and the engine seized, but I was able to free it and start it, but it runs poorly.
Its easy to rebuild and engine so long as you replace gaskets and use some gasket sealant and use correct torque on each bolt which can be found on owners manual for bike
Jun 17, 2010 | 2004 Husqvarna TE 250
Car promblem
Sounds like your oil ran low and the pistons and rods are runnig without oil. This will seize the engine check your oil if it is real low put some oil in it and try to start it. If it starts you got lucky. Tahn find out how you lost all your oil before runnig it to much. If the engine doen't turn over than your motor is no good.
Dec 08, 2009 | 2001 Dodge Stratus
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
85 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
