Nad 6220 cassette deck noise only on play back and meter readings are off the scale on all cassettes
No sound on play back and meter readings off the scale on play back
  • 1 more comment
  • ian murray Dec 24, 2012
    no change after cleanibg
  • ian murray Jan 08, 2013
    turned multiplex filter off and now working perfectly
  • Sam Palermo
    Sam Palermo Jan 08, 2013
    That is very stange that a MPX filter would introduce a noise. There is something else going on in that unit I bet.
  • Audio Player... Master
  • 1,267 Answers
Sounds like a dirty Record/ Play switch. You need to clean it with a spray like Deoxit and exercise it.
Posted on Dec 06, 2012
  • Sam Palermo
    Sam Palermo Dec 25, 2012
    Hi Ian, That would be strange but if you don't have luck with the cleaning of the record play switch, then the problem would be more serious and would have to be looked at by a Technician.
4 Suggested Answers
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
  • 319 Answers
SOURCE: Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Posted on Apr 29, 2008
petraman7
  • 1175 Answers
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Posted on Mar 25, 2010
My technics cassette deck tr575 everything seems to work all the functions all the buttons but when I put a cassette tape in the unit I see no responce on the db meter... Everything is functioning on
There are 2 long switches, maybe 4" long, called record/play switches. These can certainly cause this. Try cleaning them with the power unplugged. You would turn the cassette deck on end, so the switches are vertical. Use LPS-1 or LPS-2, and spray a very small amount in the end. Work the switch back and forth and see if that helps. Good luck.
Nov 25, 2014 | Technics RS-TR575 Single Dual Cassette...
Cassette deck high pitched noise when playing
Sometimes this is caused by the record circuit being activated due to some kind of faulty switch. At other times it's caused by a fault on the pre-amp circuit. Possibly in the power supply to it. Perhaps a faulty capacitor?
Dec 09, 2013 | Audio Players & Recorders
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
Neither of my soni rx88 cassette deck, A or B is
The little brown wheel... Do you mean the rubber idler pulleys that are brown because they've never been cleaned? If they fell off they'll need to be replaced properly by a tech.
Apr 30, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Tascam 122MKII - press play no sound, meters don't move
Look for small leaver or any contact switches. They might have become bent out of shape or broken, or have dirt in them, cutting off the sound. Also check the leads coming from the head, they might have become detached or at least you can trace where they join the PC board. If you touch where they join you should get a buzz on either channel.
Jul 22, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Play function won't disengage on Technics dual cassette deck
Remove the cover to see if any belts under the cassette player is cut. Or to see if there are any obstructions.Remove the front cover.which will remove the tape housing of the cassette player. you can check for any broken plastic compoments that might be keeping the housing from opening.Or any belts that may have been cut.
Dec 25, 2008 | Audio Players & Recorders
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
Tape shows playing but no sound
Is sound at the headphone socket?
Does the meter show audio output?
If the answer is yes to these questions check that the connections to the amp are correct and the amp is set up is ok.
Regards
John
Nov 25, 2007 | Technics RS-TR272 Single Cassette Deck
Tascam 202 Mk111
most all twin well machines will play off one deck and record to the other.
using an outboard mic preamp will allow for less noise using the sm57. balanced mic cable with 3 pin xlr/cannon connections also reduce noise.
Nov 23, 2007 | Tascam 202MKIII Single Dual Cassette Deck
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
181 people viewed this question
 Grubhead
Grubhead
