Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore elite tiro how to set defrost time setting
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
2 Suggested Answers
BMT60
  • 126 Answers
SOURCE: what should freezer setting be set for on Kenmore
2 1/2 TO 3 YOUR FRESH FOOD SECTION SHOULD BE 1 1/2 TIMES HIGHER THAN THE FREEZER.
Posted on Apr 24, 2010
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What should freezer setting be set for on Kenmore
Apr 24, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 18.5 cu ft fridge - heavy condensation/ice build up
mam please check the settings of the freezer and the refrigerator settings should be in normal mode and if u find it in normal mode then the problem is here the temperature controler is not responding to cutt off and cutt in the freezer so please check this operation.
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er dh code error on Kenmore elite trio
Jul 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker is not working, but water dispencer is OK Model Kenmore Elite 106.45422800
Hi...
Try to check this
Good luck !!
Regards
PCmania
Jul 08, 2009 | Kenmore Refrigerators
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
Nov 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
