Question about Jenn-Air JS42SEDBDA Stainless Steel Side by Side Refrigerator
Water dripping inside freezer side and temperature in freezer taking a while to recover. I was told that the drip pan was frozen therefore the water is leaking over the top and the ice buildup restricitng the airflow causing the recovery time of the temperature. Can the frozen drip pan prevent the airflow? I just had them recharge the system and there are no leaks in the sealed system.
Dave117
  • 134 Answers
SOURCE: Jenn-Air side by side fridge, leaking from the freezer
I'm not 100% sure here.. but I suspect you might have moisture in the lining of your fridge.. Not a good thing. It may mean your heater (to keep moisture out of the lining) is faulty. In that case it's quite difficult to fix.. The ice up in the lining is probably not due to a drip-pan. Sorry I haven't answered your question, but thought it worthwhile mentioning the other possibility. PS most drip-pans sit on top of the compressor under the fridge, accessible from behind the fridge. Usually there is a drain tube down to the pan. This can sometimes get blocked up & may need some cleaning solution like white king (bleach) pored down it, to get rid of mold or whatever's blocking it.
Posted on May 06, 2008
deby69
  • 16 Answers
SOURCE: water leaking from bottom of freezer compartment
the condensation drain line might be clogged.
Posted on Jan 02, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
jmgldsmth
  • 1906 Answers
SOURCE: The freezer side of my built-in side by side
the defrost thermistor is your problem: it is going low (turning off) the defrost circuit far too quickly; it is a solid state version of a gas filled cold control sensor.
It "tells" the adaptive defrost controller circuit board the condition: (frost level) of the evaporator and, intitiates the defrost mullion heater timer. if it turns off to soon defrost
mullion heaters turn off and, icing occurs. I do not know; right off hand: which boards you are alluding to; however I believe you are referring to the power supply board for the
Posted on Jul 20, 2010
Testimonial: "I will let you know after replacing the part if it fixed the problem. I tested the thermister at 32F and it shows no continuity(infinity). Many thanks"
heatman101
  • 43501 Answers
SOURCE: Jenn Air JTB2488AE Freezer Top refrigerator.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
Leaking in front of Refrigerator this morning took off front plate drip pan full looks like water over flowed from pan. no other leaks inside and out.
hum the drip pan should not get full as the heat from compressor. the way the drip system is suppose to work is that the heat causes the water to evaporate before it builds up to much in pan? Therefore u may be dripping to much water in line due to? is there a heavy build up of ice in freezer? if so bad defrost terminator or simply the cold control is set to high? the optimum setting for ur controls should be medium or half way
Mar 16, 2015 | Refrigerators
Our Crosley CS20 refrigerator/freezer has been dripping water on the floor and the bottom of the freezer has been full of ice. We defrosted the freezer, taking everything out of it, and saw there was ice...
Defrost drain is frozen. Poor hot water around it until it is clear. You will most likely have to take inside back wall of freezer off to access defrost drain. While you have it off, inspect metal pan to be sure holes aren't rusted in it. Some are aluminum, but some are steel.
Sep 05, 2017 | Crosley Refrigerators
Water dripping into the refrigerator
Sounds very common. Without seeing your refrigerator I can only imagine that you have a drain pan leak below refrigerator, defrost condensate drain line loose or missing the drain pan, frozen over drain opening inside rear wall of freezer or the defrost condensate line is blocked somewhere along its route to the condensate collection tray below refrigerator. I am not finished so plaes don't rate me until I complete. Sea Breeze
Apr 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water is leaking from inside the freezer side of
water drianage is normal, it is supposed to drip from the freezer area to a drip pan under the unit and evaporate before it gets full. check to make sure that the drip pan is properly located and exsits and that you do not have an obstruction hindering the drain opening
Aug 22, 2009 | Hotpoint Refrigerators
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Jenn-Air JS42SEDBDA Stainless Steel Side by Side Refrigerator Logo
27 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
