Question about Panasonic SD-YD250 Bread Maker
Machine won't start
I've chosen every option through each cycle type and when I press start, the light turns on, but it just sits there.
  • 7 Answers
It is normal for the bread machine to 'just sit there' for a numbr off minutes before it starts to mix; 15 min - 2 hours depending on recipe and room temperature (see page 13)
Posted on Feb 05, 2009
How to fix my washer machine ,never stops running,after finish washing,starts with the cycles again by it self
The first thing you might try (if not already done) is to unplug the washer and let it sit for a minute or two. Then plug it in and try again. Maybe a good reset of the logic board will do something.
Does this happen regardless of the cycle chosen? What if you choose spin only? Do the cycle status lights work correctly? At the end of the cycle, before it starts again, does the "cycle complete" light come on?
This problem is likely to be a faulty logic board. Sears may be able to supply one. Perhaps your unit is under warranty.
Nov 29, 2014 | Kenmore Washing Machines
Just bought a slightly used express bake oster bread machine. It worked fantastic for the first dozen loaves. Now, I plug it in and the computer panel works just fine. I can choose whatever I need to. The...
Does the machine make any noise at all when you push the Start button? In other words does it sound like a motor is turning somewhere or is the machine completely silent?
Jun 20, 2013 | Kitchen Appliances - Others
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
HI My LED light does not turn off after a wash cycle ends. And I am unable to power on the machine again and run. The panel is blank and nothing lights up or is able to be set. I've checked...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Jul 14, 2011 | LG WM0642H Front Load
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
The child/safety lock won't release at the end of a wash cycle so I'm unable to take my clothes out of the machine. I've tried a different cycle, turning the machine off, and switching the...
Thank you for contacting
You did not mention the type and the brand of your washing machine. However given bellow are some options you can try.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
In Hoover washing machine try holding down the temperature and eco/rapid options together to turn off child lock. Some series use "TEMP and OPTION" at the same time.
Please get back to us if you have further query else please accept the suggestion
Jun 17, 2011 | Washing Machines
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
Panasonic SD-YD250 Bread Maker Logo
238 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
