Question about B-52 Music
I have a B-52 all tubes guitar amp AT-100, the distortion always worked good, now, there is no sound ?
B-52 all tubes amp for guitar AT-100 So, as I said, the distortion always worked good. Now when I change with the foot switch and even, manually to the distortion channel, there is no guitar sound. It's like when you try to listen a radio station and you cannot be on it, it feels that the Amp will blow ?
  • 250 Answers
SOURCE: Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Posted on Jan 24, 2009
SOURCE: Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Posted on Feb 28, 2009
danforddan1
  • 192 Answers
SOURCE: Marshall MG10 cd guitar amp picks up radio frequency?
First of all I would call the radio station and let the know that there over modulating just a bit.this has happened to me a few times even on my tel/phone. I use to get WOKO on my amp. You can try and move the amp to diffrent location , reverce the polarty switch on the back , not much more you can do. But watch out when you here music comming from you toster your in big trouble, just kidding. Good luck DFD
Posted on Apr 13, 2009
danforddan1
  • 192 Answers
SOURCE: amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
soundchasr
  • 11 Answers
SOURCE: guitar amp channel switch repair
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Posted on May 29, 2009
There is no sound coming out of my Marshall 100 watt tube amp head?
make sure the standby switch is operating correctly.Sounds like the power tube.
Dec 18, 2013 | Marshall Amplification Marshall JCM800...
FM 65R plays and sounds great for about 5- 10 minutes then it sounds weak and distorted. If I play directly into the power amp input it sounds great again just no control for the volume and tone.
Also the volume will probably be lower going into the line level PA input... If the amp is shutting down for thermal reasons, driving it less might not get to the point of shutdown. The schematic shows a temp sensor that reduces and shuts down the amp if the heatsinks get to hot. Possibly you are driving the amp harder than it is intended, If it is as loud (I doubt it) driving the PA input, then I would expect it to shutdown, but you would probably have to drive it harder than your guitar because guitar levels are well below line level. The amp claims 65 watts... don't believe everything you read in spec sheets... You should be able to generate 100 Db of sound with it... The more distortion you use will drive the amp harder and heat the heatsinks faster.
May 13, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Bought amp 1 year ago, three months ago, no sound, Guitar Center said call an authorized repair shop. I did'n't open it up to check fuse because i didn't want to void the warranty. The shop replaced the...
Possible that the output tubes that were replaced are drawing too much current, hence the popping sound (may be "motorboating", one common word to describe a similar sound)
This means the tubes need to be biased properly. You need to get it to someone who knows what they are doing, ie a good amp tech, not GC. The voltages here are dangerous.
Feb 25, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
Fender Hot Rod Deluxe Volume Fluctuations. My amp (fender hot rod deluxe) will occasionally have volume fluctuations when I'm playing. The changes usually occur when I've moved my setup from one place...
First thing would be try another guitar with the amp. This will eliminate if it's a problem with the guitar or the amp itself. If the guitar is working properly then check all the tubes to be sure they are all seated into there slots completely. Depending on how much use they have been played it may be a good suggestion to then replace your tube's. Occationally the tubes will start loosing power, making sound fluctuate up and down or distortion sounding static in background noise. You will notice a big difference with newer tube. But remember the bias must be set correctly to match the new tubes so they won't over heat. You can check out youtube for setting the bias. Anyway this is my suggestion and I wish you good luck.
Jan 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Amp sound fuzzy and out of tone.
Well if you want goo dpinch harmonics to squeal you need a decent amount of gain and good pickups. What guitar are you using, some lower model passive pickups have bad frequency response when you try to do pinch harmonics. If you have decent pickups I would say get a higher gain preamp and just run the amp on the clean channel. There a re tube preamp pedals out there that have masaive amounts of gain and they are reasonably priced. There are also so good amps out there for a decent price like the 6550 from peavey. I have a 5150 block letter and that thing can produce good pinch harmonics along with my EMGs. Good luck man, oh and there is nothing wrong with your amp, it is just time to move on. There is only so much you can do with solid state amplifiers in my opinion.
Jan 13, 2010 | Music
Not getting enough distortion(esp ltd ax-260)
It's not your pickups. It would be nearly impossible to loosen a wire inside of your guitar by having even heavier than your amp head drop on it. It is most likely your volume pot. The post, if hit hard enough, can virtually distroy your pots. Another possibility could be your jack, al though considering where it's located on your guitar, it would be very hard to damage it by having something drop onto it.
There is little else that could be the problem. Hopefully you didn't damage your guitar too badly. If the guitar was in front of me, it would be a relatively easy diagnosis.
Fortunately, volume and tone pots are inexpensive, and if you're handy with a soldering iron (or you have a friend that is) it is an easy install with four to six solder points, depending on your configuration. I don't want to assume it's a stock setup, but when you take off the rear electronics cover, you will immediately see what configuration you have.
If you have possibly damaged the pickup bobbins (assuming you have the stock humbuckers in your guitar), you would be able to see the damage, It would either look damaged,or work correctly. As you know bobbuns are simply wound wire, and that's not easy to damage. Plus your strings provide a minimal amount of protection, unless your amp head slammed it very hard. Start by replacing the volume pot. Cheapest parts first. There is no way to test the pot with anything like a potentiometer, because there is virtually no voltage that passes through the pot. Additionally, unless you have active pickups, your pickups cannot be either. If you do have to replace your electronics, you can find a large variety and even upgrade your parts by searching eBay. The good thing is that you havce a guitar, and guitar parts are abundant, relatively cheap, and most people change out electronics just to achieve a different sound.
If you are so inclined, most good guitar shops will diagnose your problem for cheap and apply the cost of the diagnosis to the cost of the repair. Good luck, and I hope I have given you some information to work with.
Thank you for using FixYa
Jun 19, 2009 | ESP Ltd EX-50 Electric Guitar
Crate tube amp will not power up but cooling fan tries to run
Yes.
Are you saying that the only indication that it is running at all is that the fans are running? So the tubes don't light up? No indicators on the front of the amp?
Power supplies that provide multiple voltages, which your amp has, can provide some of the voltages while having a problem that prevents them from providing others, all while not blowing a fuse. If you are not confident in your ability to work on a piece of electronic equipment that has 120VAC coming in and at least 175VDC or more present inside it, bring it to a service center.
The good news is that it is probably not horribly serious. Problems like this can almost always be repaired in a cost effective manner.
Feb 11, 2009 | Crate Blackheart BH15H Handsome Devil...
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Music Logo
44 people viewed this question
Top B-52 Music Experts
Michial Gueffroy
Are you a B-52 Music Expert? Answer questions, earn points and help others
