Question about Acer Aspire 5570-2758 Notebook
Acivate the S-video port on 5570-2758
How do you activate the S-video port?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Press fn f5
Posted on Dec 08, 2012
HP w2338h monitor will not come on. When I turn the screen on it just says monitor going to sleep. What's the problem and can it be fixed?
This means that the monitor is not getting a signal from the video card. First, is your computer on?
Next, are you using the VGA or the HDMI port on the monitor? If your computer has multiple video ports, you need to make sure that your cable is connected to an active video port. If the computer has an add-on video graphics card and the on-the-motherboard video ports, make sure that you are connected to the add-on card port.
Try a different video cable and a different port. Try changing the videos source on the monitor. Make sure that the refresh rate on the computer is 60 Hz. (Many CRTs could be run at 75Hz; this is incompatible with flat panel LCD monitors. If this was the case, reconnect the CRT monitor and reset the refresh rate. In Windows 7 on a desktop computer, just right click on the desktop and select Screen Resolution. Select Advanced Settings and then the Monitor tab)
I know there have been some desktops that shipped with the HDMI port active. Thus a monitor connected to the VGA port would go to sleep. For those machines, you had to connect the monitor to the HDMI port and then change the active video port. For laptops, often the external video adapter is disabled to conserve power. This needs to be enabled (sometimes it has to be enabled in the BIOS and then in the OS).
In some cases, the problem is simpler. The monitor failed to synch with the video card. Turn off the monitor and the computer. Turn on the monitor and set it to the correct source. Then turn on the computer. Most modern OS versions will see the monitor and correctly set the resolution and refresh rate. (This often applies to TVs when used as a monitor as well.)
I hope this helps. Please add a comment with details on your computer and video graphics adapter for additional assistance.
Jan 31, 2013 | Computers & Internet
How do I acivate my wifi on my modem(2wire)
The ISP modem connects the uplink / internet (yellow) port on the Linksys Wireless-G WRT54G. You now have wireless.
Oct 08, 2012 | Linksys Wireless-G WRT54G Router
ACTIVATE EXTRA VGA PORT DELL INSPIRON
You don't have to activate them, you just plug leads in and connect the other end in to the correct device.
Feb 07, 2012 | Dell Computers & Internet
When i on my desktop it show blue screen and says no signal analog
That means that the monitor is not getting a signal from the computer. There are several possible issues involved. 1) Make sure that the computer tower is on. 2) Check that the video cable is connected to the active port on the desktop. (Computers often have video connections on the motherboard and an added video card. The motherboard connection is disabled when the video card is active. Similarly if there are several ports (VGA, DVI, HDMI, Display port) only one may be active.) 3) Try a new video cable (if possible) and one of the other video ports (again if possible). 4) Try connecting a different monitor to the computer or connecting this monitor to another computer.
Open up the computer and check if the card requires a separate power connection to the power supply. Make sure it is plugged in. Do the fans in the computer spin up?
If a second monitor doesn't work or the monitor works on another computer, then the problem is with the video adapter on the computer, the power supply or the power switch. Please add a comment with more information about the type of desktop and the current video graphics adapter (on the motherboard or separate card). I will provide additional help if possible.
(who has a computer in the company that needed a new monitor (power supply failed) a few months ago and lost the fan on the video card last week. Without the fan, the card overheated and shut down. Thus no signal to the monitor.)
Oct 02, 2011 | Computers & Internet
How to acivate 3g in vodafone sim.,?
you should have brought ur iphone from orange they are much better and get it activated within minutes for you Activating 3G in Vodafone is very simple.First insert the Vodafone SIM card in 3G enabled mobile phone.You have to send single SMS to activate the Vodafone 3G on your mobile number.The procedure is ACT 3G to 111 (For Postpaid users) and 144 (For Prepaid users) .The process for activation of 3G will be completed in maximum 24 hours.
You will get confirmation message from Vodafone when 3G service is activated.
You have to change the Network mode into UMTS or HSDPA in-order to use the High Speed Vodafone 3G service.
May 17, 2011 | Computers & Internet
Hello, I also have an RCA G32705 unit, and I have a question for you. Although the unit has Video 1 and Video 2 ports on the back, the internal menu will not allow me to activate them. The only port...
you must go on menu- set input signal and you must choose RGB or video in complex signal (1 or 2), not antenna or RF input. Coax input port is a RF input port. Your problem is only from tv menu ( input seting)
Mar 07, 2011 | Televison & Video
When I try to listen to my audiobook, a message pops up saying "Please acivate your device to play this title". How do I activate my device? (I got my audiobook from audible.com)
I think this has nothing to do with the philips mp3 player and more to do with the audible website.
~~ Activate Each installation of AudibleManager will need to be registered with Audible.com in order for our audio books to play through the software. If the audio is going to be transferred to a device or burned to CDs, each device and CD burner must be activated as well. A total of 3 AudibleManager installations are able to be registered to 1 account at 1 time. Each installation of Audible Manager may have up to 3 devices/CD burners activated at 1 time. ~~ have u done this?
from http://download.audible.com/audiblemanager/AM5_User_Guide.pdf
Mar 07, 2011 | Philips Audio Players & Recorders
How to i retrieve my password for my wireless router
http://www.intellinet-network.com/en-US/products/8152-wireless-300n-4-port-router
Visit the above mentioned website and select the tab "Videos". Under that tab, you have to watch the 1st video to retrieve your wireless password.
For further clarifications, revert!
Thanks for asking,
Regards,
Arvind S Iyer
Sep 28, 2010 | Intellinet Active Networking Intellinet...
I have a one year old Broksonic 19" flat screen LCD TV. I wanted to use it as a computer monitor, so I hooked up the VGA cord and selected PC as the input. Nothing. What am I doing wrong? Charles...
Is the computer set to send data to the video port? Laptops often have the external port disabled; check the BIOS. (This is often accessed by pressing F1, Esc or F2 before the OS loads. Check your documentation.) Then you can set the preferred monitor by looking at the Display settings.
Some desktops have a similar issue where only one port is active (DVI, HDMI, and VGA). You may need to connect a different monitor via the enabled port or use an adapter to get the VGA cable to mate with that port to change settings. (In the case of computers with video graphics cards and motherboard video ports, only one item is active. Try moving your cable with an adapter if needed to one of the other ports. Then change the BIOS setting if you do not want to continue using the adapter.)
Try a different video cable and make sure it is fully connected to both the computer and the monitor. Damaged cables are always suspect.
What OS are you using? Do you need to download drivers for the Broksonic? Go to www.broksonic.com and ask in the Product support section - they don't seem to have a direct link on the site. (For example some TVs are not compatible with the drivers in the Mac OS.)
I hope this helps.
Aug 21, 2010 | Broksonic TV
Acer Aspire 5570-2758 Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
