Question about Generic 7" cenomax f7024b-09 widescreen digital photo frame w/mp3 & 4 frame in
Cenomax F7024B powers on but screen blank
Appears to be a burned out diode or chip at the front end of the circuit board immediately below where the power source would be plugged in.
  • vblivesound
    vblivesound Dec 09, 2012
    See the attached phot for additional information regarding this problem. As I am not the most electronic-savvy (though I am handy) I need some help identifying and perhaps replacing the damaged components.
    Master:
  • 742 Answers
Buy a new one, if one part fried then several others are fried to.
Posted on Nov 15, 2014
Gps system says being activated but does not come on
1: if you navigate electricity, (with the navigation buttons backlight and the light is on) appears black screen, this is front-facing screen navigation motherboard diodes burn big thermal power flows through the electric circuit breakers in the situation you find the location of the installation let him to give you do after 2: if you don't electricity, navigation, unable to boot, you can see if your cigarette lighter and electricity, if not, congratulations you, your dashboard below there is a small resistance wire burned, to let him help you where you press the navigation in a, this can only show you the navigation of the voltage is not stable. 3: if you navigate difference, can't boot, cigarette lighter is normal, you remove the navigation, navigation and power cord with a plastic plug head, take out to see so you can take off) and see the inside of the resistance wire is disconnected, if there is change a good, if not, then you take the past to let him give you repair.auto diagnostic tool
Mar 14, 2013 | Chrysler Cars & Trucks
Some water dripped down from the floor above right on my receiver and it shut down. Now that it sat for a bit it turned on but won't go off headphone's even though no headphone's plugged in I...
When water spills on electronic products it causes corrosion to the circuit board and to the components in different circuits, unless you went inside the unit immediately after the water went into the unit and cleaned the effected areas some components and circuit traces have been already damaged and the longer the water sits inside the more damage it can do. Circuit traces may need cleanning and some capacitors or other components may need replacing because water is conductive and can create short circuits to diodes + trasistors, IC chips.
May 19, 2011 | Electronics - Others
On power up I hold the power button down, I can hear some sort of relay kick-on, sometimes a horizontal white line appears across the screen, then it kicks-off, and the red led blinks four times...
White line across the screen indicates that tv got vertical deflection failure problem that may be due to vertical output chip failure. If that kind of problem occurred, tv select protection mode and red light starts blinking 4 times.
Please check vertical output chip in tv main board and replace it to solve tv issue. This job needs soldering work so local tv repair shop will help you.
Thanks.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Mini hi-fi JVC CA-FSX3 stops after power on
Well, I disassembled the unit carefully. And I've found that diode SR303 was blown. It's very easy to find near huge pulse-code converter chip. This diode is used at power supply stabilization for amplifier that has a D-class i.e. pulse-code amplifier, and for CD part. Testing of this diode confirmed that it's dead. After a couple of days received the diode from shop, is very cheap. Changing the diode recovered all the functions of the unit. Now it works fine.
Resume: The diode was burned as a result of incorrect connection to line input. The owner of the unit haven't seen that a volume level was at maximum. The connection of line input overloaded the maximum current capacity of the diode and it was blown. As for it, I've seen that in that circuit in reality must be used a stabilization chip, that is not so cheap like a diode. I think it's a constructor's error to change the chip, that is overload protected, to a simple diode.
Waiting that my info will be useful because it´s a most vulnerable part of JVC CA-FSX3. And don't overload the amplifier!
Sep 06, 2009 | JVC FS-X3 CD Shelf System
My screen is blank and the power button keeps flashing blue
AV56wp74? The power button blinking blue means the set is in shutdown----the most common reason for this in this set is one of the two convergence chips is shorted. The way I usually prove this is to remove rear cover and or front grill and examine convergence circuit located at the front of the set----Also--I will unplug the plug from that circuit board that goes to the TV's power supply---if the set turns on with the convergence circuit board unplugged from it---you know your trouble is one of the two chips---if this is the case both have to be replaced and the set adjusted.
I do this here for free so if this has helped you give me a vote here. If you have questions or need help let me know.
Aug 27, 2009 | JVC AV-56WP74 56" Rear Projection...
Bearcat police scanner bc175xl turns on but nothing appears in window
I fixed the same problem with my BC 175xl. Open up the scanner and look on the radio receiving board, thats the board with the antenna jack on it. Check all of the diodes (diodes are very small red things with a black band on one end and short bare sliver colored leads coming out of both ends conecting it to the board) On my BC 175xl one of the leads on a diode in the lower right hand side of the receiver board had burned off. Reconect or replace any diodes that are either no longer conected to their leads or their leads no longer conected to the board. I discovered this repair on my own, after never finding anything about this on the internet
Aug 13, 2009 | Uniden Radio Communications
It being emerson 32" hdtv lcd turns on but immediately turns off
This is Emerson's #1 problem.
The Inverter Transformer on the power supply/backlight inverter board goes bad. It's what powers up the screen for your TV. When the part goes bad, it doesn't have enough juice to power the screen and the TV automatically turns off. You have 5 Inverter Transformer on your board.
You can fix the problem by replacing the whole board or replace the bad Inverter Transformer.
Here's where you can get a new board for a good price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc320em9+inverter
Or, here's where you can get replacement Inverter Transformers:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Jun 17, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Gateway GWT-P42M303 screen problem
the 15v is shorted to the ysus board and probably one of the two big heat sinks with the number 4921QP1002B is the cause. If you don't repair it can I have it for parts?
Mar 30, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Generic 7" cenomax f7024b-09 widescreen digital photo frame w/mp3 & 4 frame in Logo
497 people viewed this question
Top Generic Car Audio & Video Experts
xxxxxx xxx
Are you a Generic Car Audio and Video Expert? Answer questions, earn points and help others
