Question about Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger
Stihl grass trimmer Model FS45 sudden engine cutt off
The engine runs for about a minute or two then suddenly it loses power and cutting off. CLeaned airfilter or statred without it but problem persists. Please help.
  • shelton mcla Apr 18, 2009
    it runs but when i give it some gas it chokes off
Need stihl fs45 bearing housing
contact a stihl dealer
Sep 12, 2016 | Stihl Garden
My ryobi 30cc grass cutter model rtp 3000 runs but no power to cut gass
I have seen the flex cable broken between the power head and the cutter head .
Feb 20, 2016 | Stihl FS 85 Weed Eater
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Oct 12, 2010 | Black & Decker 14" Grass Hog Xp...
Stihl FS45 will not run at full throttle
replace fuel filter in the tank and will be fine it is gummed up .stock part at any sthil dealer
Aug 22, 2009 | Garden
Stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Aug 02, 2009 | Garden
My stihl weedeater starts and idles fine but does not get power.
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crack or split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jul 07, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Stihl FS45 2 cycle string trimmer. Bought in 5/06 Cutting head came off while cutting. Flexible shaft still has squared off end so it doesn't seem to be broken. What holds the cutting head shaft with the...
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Jun 22, 2009 | Garden
Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger Logo
1,560 people viewed this question
Top Worx Garden Experts
Vee-Max
Level 1 Expert
Tim Whalen
ray gallant
Are you a Worx Garden Expert? Answer questions, earn points and help others
