Question about LG 22" FLATRON LCD Monitor
White screen no buttons work code v3.13.0 on screen
A white screen just popped up & says to set a parental code but none of the buttons on the remote work... Can't see any picture just hear it..
Did the remote function before?
Not knowing brand and MODEL number hard to advise you other than turn off and unplug set for a minute and then turn back on.
If parental code has been entered you must enter it to use set---in this case also make sure if remote for several things you have it engaged for TV and not SAT or DVD etc.
I am here to help most of the day.
Mar 14, 2012 | Samsung Televison & Video
Where light is for controller port four its flashind red and xbox will noy work?
hi, this is what that code is telling you, also do you have a code on the screen when switched on let me know if you do if you dont ill tell you at the end of this post how to get an error code so i can tell you exactly what the problems is.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
here is how to get the secondary code for me.
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 1 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code ( so 1 red light may be lit so write this down).
* Release the eject button and press it again.( it will then change the red lights and maybe 2 will be lit up write this down also)
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 1 red flashing lights.
so what you need to do is this, when the 1 red light comes on hold down the little white sync button and keep holding it down all the time, now whilst your holding that little white button down on the front of xbox press the eject button but keep holding the white button down now write how many lights are lit up and this is the 1st number in the code, so keep holding the white button down dont let go of this white button then press and let go of the eject button again and write how many lights are lit up whilst still holding the white button down, now do this 4 times all together and you will end up with something like this written down
4402
once you have this four digit code send me a message back with the code then i can tell you exactly what the problem is and what you can do to try and solve the problem
let me know how you get on or if you need further assistance ok
Dec 12, 2010 | Microsoft Xbox 360 Console
White screen on TV.
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
Apr 24, 2010 | LG 32LH30 32 in. LCD HDTV
White screen problem nokia n70
format ur phone by this way
"Press and hold <3>, <*> and Call (Send) buttons, then power on fone, keep holding on the 3 buttons, till u come to a format screen. this method ONLY works on 6600, and need not enter the sec code. BUT sec code would be reset to default 12345."
if u r satisfied with my answer then pls vote me
Jan 21, 2010 | Nokia N70 Cellular Phone
Action replay not responding at all
how to reset the Action Replay DS OK we have finally done it!! YEAGH!. Here is the trick for those like my son and I that are trying to get the darn thing to reset. All you have to do is Hold down A&B first while the unit is off. Keep holding A&B buttons then be ready to press the Start & Select button just after you turn on the DS. Wait for the White screen to Appear after bootup, then press and hold the Start & Select buttons while still remaining to hold the A&B Buttons, before the words appear. Another words after health and saftey screen a white screen will appear that is when you add the start & select buttons along with the A&B Buttons. The white screen will stay on for 10 seconds. If it does not stay on the white screen foe about 10 Seconds, it did not work. Otherwise ours did not work until we jumpped the gun on the Liscense screen. Hope this helps someone. :)
May 19, 2009 | Nintendo Action Replay DS for DS and NDS...
Blackberry Pearl 8100c Screen blank out
i want to change the network code of blackberry peral 8100
how i can unloack the phone
IMEI = 355767018968151
Dec 22, 2008 | RIM BlackBerry Pearl 8100
Ds action replay
I just had this problem earlier today:
First, turn on your DS, and after the warning screen (at the white screen for the AR) hold these four buttons: A+B+SELECT+START, the white screen will be there for a little while longer, be patient and keep holding down the buttons
When the Menu screen shows up, let go of the buttons
Plug your DS into your computer and you will be able to add codes again. You may not have all your codes from earlier, but that's what the quick update's for (It'll be worth it to be able to input codes again)
Jul 27, 2008 | Nintendo DS Lite Console
Display problem
i also have the same problem...white screen display
May 26, 2008 | Nokia N70 Cellular Phone
Samsung E250 white screen
Hello if you want you could get it repaired or type *#8999234*348# it restarts inside the phone so u will lose all your data on phone like games music pictures videos and phone book but it will fix it or pay $80 dollars for new screen if you want more help my email is danielp1236@hotmail.com and i fix phones all time i fix them my self pay $80 or come to me ill fix it for $25 plus warranty if it stuffs again. The white on screen means it forgot what was happening and just froze white and restarting by the code, Not just turning it of by holding red button, full restart by typing the code in the call screen any more worries about mobiles send me a email.
Mar 25, 2008 | Samsung SGH-U600
LG 22" FLATRON LCD Monitor Logo
66 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
