Question about Sea Dog Battery Monitor Panel
My battery test meter sea dog line model 422020 stopped working
My batteries voltages are 12.47v but I get no readings on the moniter
Low voltage battery
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. Clip a testlite to a good ground and touch regulator pin, if light glows replace regulator.
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Feb 05, 2014 | Harley Davidson Motorcycles
Voltage regulator
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
Jan 28, 2014 | Harley Davidson Motorcycles
Charging system failure low voltage
Jan 07, 2014 | 2011 Harley Davidson FLHTK Electra Glide...
2002 Harley ultra high voltage
Sep 23, 2013 | 2000 Harley Davidson FLHTCUI Electra Glide...
Full battery on 99 sportster nothing happens when I push start button
Hi Anonymous, you could have a faulty circuit breaker, ignition, start er button, or run/stop switch then perform the following tests:
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
17. For a free wiring diagram please visit the website below and good luck.Harley Davidson Wiring Diagrams and Schematics
Sep 11, 2013 | Harley Davidson XL 1200 C Sportster Custom...
Voltage regulator rectifier
Hi Mike, perform the following tests:
Jun 13, 2013 | 2011 Harley Davidson FLSTF Fat Boy
2000 hd flhtcu doesnt charge battery when running
Apr 10, 2013 | 2007 Harley Davidson FLHTCU Ultra Classic...
Showing 13.9 to 14.3 volts at battery at idle. At higher rpm voltage drops dramatically. Have replaced voltage regulator. Any ideas?
Hi Kevin, perform the following tests:
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Mar 25, 2013 | 2011 Harley Davidson FXDB Street Bob
I have a 93 ultra when I apply the brakes all my gauges dump and the brake light stops working and the directional any help or ideas???
Hi Sargesmit845, perform the following tests:
Jun 05, 2012 | 2003 Harley Davidson FLHTC Electra Glide...
99 Roadking EFI, engine light came on, lights dimmed, speedodometer stuck at seventy. R&R battery worked fine for a short ride, now same result. Ohm'd coil, 4 ohms. pins to ground is high ohms Running...
Hi Mitch_steven, perform the following tests:
May 01, 2010 | 2000 Harley Davidson FLHRCI Road King...
Sea Dog Battery Monitor Panel Logo
48 people viewed this question
Top Sea Dog Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Sea Dog Boating Expert? Answer questions, earn points and help others
